Hello guys, i got an issue with my limeSDR.. here’s the detail :
Device: LimeSDR Mini 2.0
Issue: Device no longer detected after firmware update
Description:
After running LimeUtil --update which completed successfully (100%), I physically disconnected and reconnected the device as instructed. Since then, the device is completely undetectable:
LED is on (VBUS power present)
Does not appear in lsusb on Linux (tested on multiple machines)
Does not appear in Windows Device Manager when plugged/unplugged
Does not appear in LimeSuite GUI → Connection Settings on Windows native (no VM)
Zadig shows no LimeSDR entry even with “List All Devices” enabled
Prior to the firmware update, the device was connecting successfully (Make connection: ‘LimeSDR Mini [USB 2.0] 1DA1542270731D’) but was producing VCO lock errors:
[ERROR] TuneVCO(CGEN) - failed to lock (cmphl!=0)
[ERROR] SetFrequencyCGEN failed
[ERROR] setSampleRate(Rx, 0, 2 MHz) Failed
The firmware update was intended to resolve these errors. The update completed at 100% but the device became undetectable after the subsequent reconnect.
do you guys have any idea what’s going on with my device? is there still a way to recover from this?
Thank you!
