I am trying to connect LimeSDR to an embedded PC through it’s mPCIe interface. The connections seems fine but I am unable to get any data using the generic example FW images like GpifTousb (to test system throughput).
In short, loading GpifToUsb.img into FX3 (LimeSDR recognized as StreamerExample) and running application “Streamer” to get data throughput under Windows 7 32-bit.
It gives the following error:
“Xfer request rejected. NTSTATUS = c0000001”
While the same procedure works fine if I connect LimeSDR through USB3.0 port directly. Can it be a driver issue or something else?
Thanks in advance.
Regards
