LimeSDR board test fail
Hi All.
I purchased a LimeSDR back in April and it was working pretty well other than occasional calibration issues. Yesterday, I noticed transmission power to be well down and I could no longer calibrate the unit after many tries. I plugged the unit into my LimeRFE device and thats when it decided to fail. I tested the LimeRFE with a Lime Mini I have and there was no issues. I ran several board tests afterward and the RF tests fail. Is anyone able to offer advise?
->Start time: Tue Aug 11 18:04:33 2026
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009083401881A29, index=0, HW=4, GW=2.23
Serial Number: 0009083401881A29
Chip temperature: 39 C
->FX3 GPIF clock test
Test results: 18729; 22485; 26241 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112967 (min); 5113105 (max) - PASSED
->Clock Network Test PASSED
->Read data: 19 01 15 19 01 15 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.4 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-17.3 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 → LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-44.0 dBFS, -20.00 MHz) - FAILED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-18.4 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-19.5 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-14.9 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 4.63 seconds
The only other odd thing is that the Mini also fails some of the tests, but appears to work fine.
Shane.
Given the test results I assume you were using TX1_1?
Could you also post the LimeQuickTest results for this.
Hi Andrew.
Thanks so much for the reply!
To answer your first question, Yes, I was using TX1_1
Below is the test for the LimeSDR Mini.
->Start time: Thu Aug 13 03:59:01 2026
->Device: LimeSDR Mini, media=USB 3, module=FT601, serial=1D588EB71F6314, index=0, HW=3, GW=1.30
Serial Number: 1D588EB71F6314
Chip temperature: 15 C
->REF clock test
Test results: 39108; 52305; 65502 - PASSED
Results : 6710959 (min); 6711121 (max) - PASSED
->Read data: 13 0A 16 13 0A 16 02
->Run Tests (TX_2 → LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-23.6 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 → LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-18.9 dBFS, 5.00 MHz) - PASSED
Elapsed time: 5.79 seconds
Thanks
Shane.
Tagging @zack and @Karolis . Though there may be a delay with colleagues on vacation.
Thank you for your reply.
Any advise they could give will be appreciated.
Shane.
