Limesdr-usb board test multiple failures
I have tried updating board, not sure if I need to buy a new one?
$ LimeQuickTest
->Start time: Wed Aug 19 06:12:50 2026
->LimeSuite version: 20.10.0-PothosSDR-2021.07.25-vc16-x64
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009060B00472A22, index=0, HW=4, GW=2.23
Serial Number: 0009060B00472A22
Chip temperature: 41 C
->FX3 GPIF clock test
Test results: 29883; 33639; 37395 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112978 (min); 5113107 (max) - PASSED
->Clock Network Test PASSED
->Read data: 2F 28 00 EB 00 00 A0
->FPGA EEPROM Test FAILED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-14.6 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-16.8 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 → LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-36.7 dBFS, 5.00 MHz) - FAILED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-23.9 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-16.2 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-14.4 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 6.77 seconds
Looks like there may have been some damage on LNA_W input, but LNA_L and LNA_H inputs are still in spec. Which Rx inputs have you been using?
I found the balun is bad. Ordered a new one.
Thank you very much,
Ed
