Exactly what I am seeing also.
I am also running into this. Is there a resolution to this issue?
Loading configuration from: “/home/emilian/.config/gqrx/default.conf”
Configuration file: “/home/emilian/.config/gqrx/default.conf”
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.11
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
[INFO] Make connection: ‘LimeSDR-USB [USB 3.0] 9060B00493215’
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
[INFO] Ver=7, Rev=1, Mask=1
CGEN: Freq=80 MHz, VCO=2.56 GHz, INT=82, FRAC=349525, DIV_OUTCH_CGEN=15
CGEN: Freq=61.44 MHz, VCO=2.4576 GHz, INT=79, FRAC=0, DIV_OUTCH_CGEN=19
M=156, N=3, Fvco=1040.000 MHz
16: 20 A8 2A
16: AA FA 5D
19: FF FF FF
phase: min 31.2; max 197.3; selected 114.2)
16: AA 52 D5
phase: min 5.2; max 176.5; selected 90.9)
16: FE AF 2A
16: AA DA 55
19: FF EF FF
16: D7 DC 3F
16: AA 58 75
16: AA 5A D5
phase: min 15.6; max 171.3; selected 93.5)
MCU programming : 16384/16384
MCU Programming finished, 1146 ms
phase: min 5.2; max 360.0; selected 182.6)
FATAL: destination port 1 out of range for source_impl(47)
Trying to fill up 18446744073709551615 missing channel(s) with null source(s).
due to gnuradio bug #528.
terminate called after throwing an instance of ‘std::invalid_argument’
what(): destination port 2 out of range for source_impl(47)
I only experience this on some computers, so I assume it is crappy USB3 hardware in that PC
I have too …
Not offten … its not a USB2.0/ USB3.0 issue …
Unplug and wait 5 seconds… plug back in …
Try again … usally takes me 4 trys to get my version to show correctly …
