I’m experiencing the same issues trying to run gqrx that robertkb and others have had, but for others things eventually seem to work. Not me, so far.
I installed first using the directions in section 2.1 of the startup. Then ran LimeSuiteGUI and it worked fine. Ran loopback test, then monitored a chunk of spectrum with the FFT application - all fine.
Then tried gqrx, no go. (output pasted below)
Made sure everything is up to date (update, upgrade).
Tried many sample rates in the gqrx setup for LimeSDR, copying what worked for someone else in another thread (with both the gqrx default and their device string). Still no joy.
Then at the advice above from wb8lbz_Larry, ran the install instructions from section 3.1.1. Still no joy.
Ran gqrx with sudo, in case there’s a permission problem. Still no joy.
Does anyone know what the root cause of this problem is? I hate to have to just install everything from source and hope for the best!
Thanks!
Steve
$ uname -a
Linux sdr2 3.13.0-112-generic #159-Ubuntu SMP Fri Mar 3 15:26:07 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
$ gqrx
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.010.001.001-release
Controlport disabled
No user supplied config file. Using “default.conf”
gr-osmosdr v0.1.x-xxx-xunknown (0.1.5git) gnuradio 3.7.10
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy soapy redpitaya
FM demod gain: 1.52789
IQ DCR alpha: 1.04166e-05
Using audio backend: auto
BookmarksFile is /home/srb/.config/gqrx/bookmarks.csv
getDeviceList : Available input devices:
0 : “Realtek RTL2838UHIDIR SN: 00000001”
1 : “RFSPACE SDR-IQ Receiver”
2 : “RFSPACE SDR-IP Receiver”
3 : “RFSPACE NetSDR Receiver”
4 : “RFSPACE Cloud-IQ Receiver”
5 : “LimeSDR-USB [USB 3.0] 9060B00461923”
6 : “RTL-SDR Spectrum Server”
7 : “Red Pitaya Transceiver Server”
8 : “Complex Sampled (IQ) File”
Loading configuration from: “default.conf”
Configuration file: “/home/srb/.config/gqrx/default.conf”
Crash guard triggered!
Launching I/O device editor
firstTimeConfig
CIoConfig : Available output devices:
0 : “Built-in Audio Analog Stereo”
saveConfig
Output device 1 : “alsa_output.pci-0000_00_1b.0.analog-stereo”
Loading configuration from: “/home/srb/.config/gqrx/default.conf”
[INFO] Make connection: ‘LimeSDR-USB [USB 3.0] 9060B00461923’
Estimated reference clock 30.7197 MHz
Selected reference clock 30.720 MHz
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
LMS7002M values cache at /home/srb/.limesuite/LMS7002M_cache_values.db
[INFO] Ver=7, Rev=1, Mask=1
CGEN: Freq=80 MHz, VCO=2.56 GHz, INT=82, FRAC=349525, DIV_OUTCH_CGEN=15
[INFO] SoapyLMS7::setFrequency(Rx, 0, BB, 0 MHz)
[INFO] SoapyLMS7::setFrequency(Tx, 0, BB, 0 MHz)
[INFO] SoapyLMS7::setAntenna(Tx, 0, BAND1)
[INFO] SoapyLMS7::setGain(Rx, 0, PGA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 0, LNA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 0, TIA, 0 dB)
[INFO] SoapyLMS7::setGain(Tx, 0, PAD, -50 dB)
[INFO] SoapyLMS7::setSampleRate(Rx, 0, 10 MHz), CGEN=80 MHz, ADC=20 MHz, decim=2
ConnectionSTREAM::ConfigureFPGA_PLL(tx=20MHz, rx=10MHz)
----- FPGA PLL #1 CONFIG -----
M=156, N=3, Fvco=1040.000 MHz
Configured phase: 0.0 (steps 0)
Configured phase: 114.2 (steps 132)
----- FPGA PLL #0 CONFIG -----
M=182, N=7, Fvco=1040.000 MHz
Configured phase: 100.4 (steps 58)
[INFO] SoapyLMS7::setSampleRate(Tx, 0, 10 MHz), CGEN=80 MHz, DAC=20 MHz, interp=2
ConnectionSTREAM::ConfigureFPGA_PLL(tx=10MHz, rx=10MHz)
Configured phase: 95.2 (steps 110)
[INFO] SoapyLMS7::setBandwidth(Rx, 0, 30 MHz)
[INFO] Rx Filter calibrated from cache
[INFO] SoapyLMS7::setBandwidth(Tx, 0, 30 MHz)
[INFO] Tx Filter calibrated from cache
[INFO] SoapyLMS7::setFrequency(Rx, 1, BB, 0 MHz)
[INFO] SoapyLMS7::setFrequency(Tx, 1, BB, 0 MHz)
[INFO] SoapyLMS7::setAntenna(Rx, 1, LNAL)
[INFO] SoapyLMS7::setAntenna(Tx, 1, BAND1)
[INFO] SoapyLMS7::setGain(Rx, 1, PGA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 1, LNA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 1, TIA, 0 dB)
[INFO] SoapyLMS7::setGain(Tx, 1, PAD, -50 dB)
[INFO] SoapyLMS7::setSampleRate(Rx, 1, 10 MHz), CGEN=80 MHz, ADC=20 MHz, decim=2
[INFO] SoapyLMS7::setSampleRate(Tx, 1, 10 MHz), CGEN=80 MHz, DAC=20 MHz, interp=2
[INFO] SoapyLMS7::setBandwidth(Rx, 1, 30 MHz)
[INFO] SoapyLMS7::setBandwidth(Tx, 1, 30 MHz)
FATAL: destination port 1 out of range for source_impl(45)
Trying to fill up 18446744073709551615 missing channel(s) with null source(s).
due to gnuradio bug #528.
terminate called after throwing an instance of ‘std::invalid_argument’
what(): destination port 2 out of range for source_impl(45)
Aborted (core dumped)
