Good morning
Is there a chance to use eclipse to build all the library? and the applications…
Thank You
Pietro
Good morning
Thank You
Pietro
Please share your experience.
I need to know if it is possible to build the projects on eclipse using the GCC compiler on windows.
Thank You
Pietro
What library? Which applications? You’ll need to be a bit more specific!
Thank You for coming here…
I have installed the suite and it is working with VisualStudio.
I want to work with eclipse.
My question is : is it possible to build the same projects in eclipse?
In another way if I use the compiled dll with the microsoft compiler is it still good to use with eclipse and GCC compiler?
It is enough for me to build new projects with Eclipse still using the dll produced by the visualstudio…
Thank You
Pietro
OK, it sounds like you mean Lime Suite, so I’ve set the category accordingly.
Thank You again for the follow up.
Yes I would like to build the limesuite. Or it is enough to grab the DLL out of the VisualStudio build, and use in the eclipse with the GCC compiler for the further work.
I am trying but not the right clue…
Thank You
Pietro
