Hello, I’m new here and thank you in advance for your support.
Since some days I’m struggling to compile the Lime Suite. I’m trying to do it on Windows 10 (fully up-to-date). My objective is to use the examples (basicTX, RX, etc.) as a base for further applications developed on C++ and therefore I have to be able to compile it (and not use the Lime Suite GUI for configuring my solution).
I found at least 3 tutorials how to do it and they all look a bit different to me (some different steps, different SW versions, not all say the same components are required, confuse to understand the whole picture). I tried to strictly follow all of them from scratch and no one led me to a successful compilation. I got all sort of warnings and errors, specially linking errors due to missing libraries and not matching syntax.
Is there an up-to-date tutorial that was made and validated from scratch maybe unifying all these other tutorials? I saw some files like the LimeSuite.h was changed not so long ago. Is it possible that there are some compatibility issues when using this new file and trying to compile the Lime Suite using an old recipe?
Thanks again for the support and best regards!
