How to fix the error: Tx Calibration: MCU error 4 (SXT tune failed)
Hi @BlackF,
Thanks for update.
hello ,my limeSDRmini HW v1.2 many years ago it stopped working (unsuccessful calibration). Now LimeSuite version: 20.07.2-gf2d96ff0 and LimeSuite version: 23.11.0+dfsg-2build2
->Run Tests (TX_2 -> LNA_W):
  CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-69.1 dBFS, -7.68 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
  CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-71.4 dBFS, -7.68 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Any ideas? Is this a hardware issue?
I tried gqrx to look at neighboring FM transmitters, but there was silence at waterfall. Therefore, I dare to assume that one SKY13411-374LF is not working correctly.
Should I check if RFSW TX/RX signals are coming to RF SWITCH or just replace chips? If there are no signals, the problem may be software related.
I blew off the commutator microcircuit with a hair dryer. And connected the antenna directly to both transformers - the result is negative. The receiver is silent.
I make a suggestion - the problem is related to the software. I have already tried all available firmwares, I will try again (Altera USB blaster it is ready)))).
