I have the same problem, 1.30gateway
Same error.
[ERROR] Tx Calibration: MCU error 4 (SXT tune failed)
Anyone been able to fix this reliably? cooling and low power issues haven’t resolved this.
Can you try building Lime Suite from source using the master branch.
https://wiki.myriadrf.org/Lime_Suite#Building_from_source
(omit the step that checks out the stable branch)
@andrewback, I tried to build LimeSuite from source as you said but it does not change the error.
@andrewback
I built LimeSuite from source using the latest commit as you advised, but still get the same error "Tx calibration:MCU error 4 (SXT tune failed) when I run srsenb.
External supply solved this problem ?
Any update on this error?
i get this error every time i try to calibrate. i always have to go into stx and do the settings there first then calibrate.
why cant they fix this. you would think it would be simple.
What version of Lime Suite are you using? And could you try building from git master.
Looks from your post from October 2019 that your board is failing LimeQuickTest?
@en1gma @BlackF @Bourascom could you please run LimeQuickTest and post the results if these contain any failures.
No Fails for me when running LimeQuickTest
Thanks, if you could post the output when running the eNodeB, showing the error.
Freshly compiled from master
$ ./build/srsenb/src/srsenb --rf.device_name soapy
linux; GNU C++ version 7.3.0; Boost_106501; UHD_003.010.003.000-0-unknown
--- Software Radio Systems LTE eNodeB ---
Reading configuration file /etc/srslte/enb.conf...
Built in Release mode using commit 0ec49a7b1 on branch master.
Opening 1 channels in RF device=soapy with args=default
Soapy has found device #0: addr=24607:1027, driver=lime, label=LimeSDR Mini [USB 3.0] 1D588F01B6A2F2, media=USB 3.0, module=FT601, name=LimeSDR Mini, serial=1D588F01B6A2F2,
Selecting Soapy device: 0
[INFO] Make connection: 'LimeSDR Mini [USB 3.0] 1D588F01B6A2F2'
[INFO] Reference: 40 MHz
Setting up Rx stream with 1 channel(s)
Setting up Tx stream with 1 channel(s)
[INFO] RX LPF configured
[INFO] Filter calibrated. Filter order-4th, filter bandwidth set to 5 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
[INFO] TX LPF configured
Available device sensors:
- clock_locked
- lms7_temp
Available sensors for Rx channel 0:
- lo_locked
[INFO] Rx calibration finished
State of gain elements for Rx channel 0 (AGC not supported):
- TIA: 9.00 dB
- LNA: 30.00 dB
- PGA: -4.00 dB
State of gain elements for Tx channel 0 (AGC not supported):
- PAD: 45.00 dB
- IAMP: 0.00 dB
Rx antenna set to LNAH
Tx antenna set to BAND1
Warning: Failed to create thread with real-time priority. Creating it with normal priority: Cannot allocate memory
==== eNodeB started ===
Type <t> to view trace
[INFO] Filter calibrated. Filter order-4th, filter bandwidth set to 11.52 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
Setting frequency: DL=2685.0 Mhz, UL=2565.0 MHz for cc_idx=0
Tested with latest LimeSuite version from Master too (20.07.2-gccb39226).
OS: Ubuntu 18.04
This is a result of my investigation and subsequent workaround implemented two years ago in stream management. With my application (which has an additional layer through gr-osmosdr wrapping SoapySDR) I can reproduce this error or lack of reliably by adding or removing the workaround.
Steps to reproduce and generated console output below:
Workaround is in place, RX stream stopped prior to creation of TX stream:
- Create and start SoapySDR RX stream
gr-osmosdr 0.2.0.0 (0.2.0) gnuradio 3.8.2.0
built-in source types: file fcd rtl rtl_tcp uhd hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
[INFO] Make connection: ‘LimeNET-Micro [USB 2.0] 583A25BFD101’
[INFO] Device name: LimeNET-Micro
[INFO] Reference: 30.72 MHz
[INFO] Selected RX path: LNAL
- RX stream stopped (not destroyed), TX stream created and started
built-in sink types: uhd hackrf bladerf soapy redpitaya freesrp file
[WARNING] TXLPF set to 5.000 MHz (requested 1.000 MHz [out of range])
[INFO] Selected TX path: Band 2
[WARNING] TXLPF set to 5.000 MHz (requested 1.500 MHz [out of range])
[INFO] Tx calibration finished
After TX stream started, RX stream is resumed (part of workaround)
No workaround in place, RX stream is not stopped prior to start of TX stream.
At this point samples are flowing through the RX stream
TX stream start
Observe error at line 5 at final step above.
And apologies for the formatting.
Regards,
Adrian
I did the LimeQuickTest with two different Gatewares:
en1gma@M4800:~$ LimeQuickTest
->Start time: Wed Oct 14 17:03:32 2020
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3BD0C4F0CDFF, HW=1, GW=1.28
Serial Number: 1D3BD0C4F0CDFF
Chip temperature: 45 C
->REF clock test
Test results: 2563; 15760; 28957 - PASSED
Results : 6710985 (min); 6711150 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 03 10 12 03 10 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 → LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-28.6 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 → LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-11.7 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.47 seconds
->Start time: Wed Oct 14 17:05:24 2020
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3BD0C4F0CDFF, HW=1, GW=1.30
->REF clock test
Test results: 2318; 15515; 28712 - PASSED
Results : 6710985 (min); 6711151 (max) - PASSED
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-28.7 dBFS, 5.00 MHz) - FAILED
Elapsed time: 2.45 seconds
en1gma@M4800:~$
Hi @BlackF,
Could you try to tune SXT using LimeSuiteGUI and check if it can deliver the LO frequency of
2685.0 Mhz. Perform these steps:
- Connect to the board;
- Push “Default” button;
- Go to SXT tab, set “Frequency” to 2685 MHz and push “Calculate” button;
- Check “VCO Comparators” values. High should be 1; Low should be 0;
- Copy and share log output here, please.
HI @Zack,
[10:18:40] INFO: Disconnected control port
[10:19:00] INFO: Reference clock 40.00 MHz
[10:19:00] INFO: Connected Control port: LimeSDR-Mini FW:6 HW:3 Protocol:1 GW:1.30 Ref Clk: 40.00 MHz
[10:19:06] INFO: SXT frequency set to 2685.000000 MHz
As you said, the “VCO Comparators” values are: High 1; Low 0;
Here is the same test with DEBUG enabled
[10:21:49] INFO: Disconnected control port
[10:21:58] DEBUG: Claimed Interface
[10:21:58] DEBUG: Estimated reference clock 40.0016 MHz
[10:21:58] INFO: Reference clock 40.00 MHz
[10:21:58] INFO: Connected Control port: LimeSDR-Mini FW:6 HW:3 Protocol:1 GW:1.30 Ref Clk: 40.00 MHz
[10:22:03] DEBUG: INT 57, FRAC 385875, DIV_OUTCH_CGEN 18
[10:22:03] DEBUG: VCO 2334.72 MHz, RefClk 40.00 MHz
[10:22:03] DEBUG: csw 153; interval [150, 156]
[10:22:03] DEBUG: M=160, N=4, Fvco=614.400 MHz
[10:22:20] DEBUG: INT 130, FRAC 262144, DIV_LOCH 0, EN_DIV2_DIVPROG 0
[10:22:20] DEBUG: VCO 5370.00 MHz, RefClk 40.00 MHz
[10:22:20] DEBUG: ICT_VCO: 192
[10:22:20] DEBUG: TuneVCO(SXT) - VCO too low
[10:22:20] DEBUG: VCOL : csw=0 tune fail
[10:22:20] DEBUG: csw=64 cmphl=3
[10:22:20] DEBUG: csw=32 cmphl=0
[10:22:20] DEBUG: csw=48 cmphl=0
[10:22:20] DEBUG: csw=56 cmphl=2
[10:22:20] DEBUG: csw=60 cmphl=2
[10:22:20] DEBUG: csw=62 cmphl=2
[10:22:20] DEBUG: csw=63 cmphl=2
[10:22:20] DEBUG: CSW: lowest=55, highest=63, selected=59
[10:22:20] DEBUG: csw=192 cmphl=3
[10:22:20] DEBUG: csw=160 cmphl=3
[10:22:20] DEBUG: csw=144 cmphl=3
[10:22:20] DEBUG: csw=136 cmphl=3
[10:22:20] DEBUG: csw=132 cmphl=3
[10:22:20] DEBUG: csw=130 cmphl=3
[10:22:20] DEBUG: csw=129 cmphl=3
[10:22:20] DEBUG: Failed to lock
[10:22:20] DEBUG: cmphl=2
[10:22:20] DEBUG: VCOM : csw=59 tune ok
[10:22:20] DEBUG: TuneVCO(SXT) - VCO too high
[10:22:20] DEBUG: VCOH : csw=0 tune fail
[10:22:20] DEBUG: Selected: VCOM
[10:22:20] INFO: SXT frequency set to 2685.000000 MHz
Hi @BlackF,
Thanks for information. Let me check.
Thank you @Zack. Today (23/10) I took the liberty to recompile LimeSuite (20.07.2-gf2d96ff0) since I saw various changes around calibration.
Please find the srsenb output bellow
- clock_locked
- lms7_temp
- lo_locked
- TIA: 9.00 dB
- LNA: 30.00 dB
- PGA: -4.00 dB
- PAD: 45.00 dB
- IAMP: 0.00 dB
connect(): Connection refused
Failed to initiate SCTP socket. Attempting reconnection in 10 seconds
I don’t see the error now
Thank you all
