Dear concern,
I am trying to build srslte network with Limesdr mini board v1.3 . every time while running srsenb am getting the error "Tx calibration : MCU error 4( SXT tune failed) .To address this issue I have tried all the solution "How to fix the error: Tx Calibration: MCU error 4 (SXT tune failed) " given here. But all these didn’t work. your valuable suggestions can help me to proceed.i will highly appreciate your help.
Best regards,
Rozana Alam
Could you please run LimeQuickTest and post the results. Please make sure that nothing is connected to the RF ports when this is run and also that the board is cold.
Thanks for your reply. Following is the output of " `LimeQuickTest" for your reference:
LimeQuickTest
->Start time: Wed Oct 14 10:47:00 2020
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D58975046C58F
Serial Number: 1D58975046C58F
->REF clock test
Test results: 50949; 64146; 11807 - PASSED
Results : 6711003 (min); 6711160 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 0A 17 13 0A 17 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-13.0 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-13.6 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 2.33 seconds
Hi @Rozana,
Could you use the latest LimeSuiteGUI and update the gateware. Then use the latest LimeQuickTest and post the log file again. Try srsLTE again after update.
Hi Zack, I ran exactly the same test here https://discourse.myriadrf.org/t/how-to-fix-the-error-tx-calibration-mcu-error-4-sxt-tune-failed/4465/36 with the master versions of both srsLTE and LimeSuite
Maybe worth merging the threads.
