I have clock problem with osmocom and limesdr mini . How Can I solve this problem ?
My gateway 1.30
Ubuntu 20.04 lts
LimeSuite LMS7002 software version 20.10.0-ga45e482d
root@murat-VivoBook-14-ASUS-Laptop-X407MA-X407MA:/etc/osmocom# osmo-trx-lms -C osmo-trx-limesdr.cfg
<0008> telnet_interface.c:104 Available via telnet 127.0.0.1 4237
<000f> control_if.c:916 CTRL at 127.0.0.1 4236
<0000> osmo-trx.cpp:609 [tid=140461422071296] – Transceiver active with 1 channel(s)
<0005> LMSDevice.cpp:1033 [tid=140461422071296][chan=0] Setting Rx Freq to 9.14e+08 Hz
<0005> LMSDevice.cpp:1003 [tid=140461422071296][chan=0] Setting Tx Freq to 9.59e+08 Hz
<0002> Transceiver.cpp:982 [tid=140461422071296] Changing TSC from 0 to 7
<0000> Transceiver.cpp:290 [tid=140461422071296] Starting the transceiver
<0005> LMSDevice.cpp:563 [tid=140461422071296][chan=0] Setting RX gain to 36.5 dB
<0006> LMSDevice.cpp:187 [tid=140461422071296] Rx LPF min bandwidth is 4MHz when TIA gain is set to -12 dB
<0006> LMSDevice.cpp:187 [tid=140461422071296] Tx Calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)
<0000> Transceiver.cpp:286 [tid=140461422071296] Transceiver already running
<0005> LMSDevice.cpp:563 [tid=140461422071296][chan=0] Setting RX gain to 1 dB
<0001> Transceiver.cpp:1148 [tid=140461301806848] Sending CLOCK indications
<0005> LMSDevice.cpp:942 [tid=140461310199552][chan=0] Tx Dropped packets by HW! (0 -> 2)
<0005> LMSDevice.cpp:601 [tid=140461422071296][chan=0] Setting TX gain to 0 dB (~0 dBm)
<0005> LMSDevice.cpp:942 [tid=140461310199552][chan=0] Tx Dropped packets by HW! (2 -> 3)
<0005> LMSDevice.cpp:942 [tid=140461310199552][chan=0] Tx Dropped packets by HW! (3 -> 4)
<0005> LMSDevice.cpp:942 [tid=140461310199552][chan=0] Tx Dropped packets by HW! (4 -> 6)
<0005> LMSDevice.cpp:942 [tid=140461310199552][chan=0] Tx Dropped packets by HW! (6 -> 7)
^Csignal 2 received
shutting down
<0000> osmo-trx.cpp:566 [tid=140461422071296] Shutting down transceiver…
<0000> Transceiver.cpp:348 [tid=140461422071296] Stopping the transceiver
<0000> Transceiver.cpp:374 [tid=140461422071296] Transceiver stopped
