sudo osmo-trx-lms -C osmo-trx-limesdr.cfg
Info: SSE3 support compiled in and supported by CPU
Info: SSE4.1 support compiled in and supported by CPU
Mon Jul 20 02:01:38 2020 DLGLOBAL <0008> telnet_interface.c:104 Available via telnet 127.0.0.1 4237
Mon Jul 20 02:01:38 2020 DLCTRL <000f> control_if.c:911 CTRL at 127.0.0.1 4236
Mon Jul 20 02:01:39 2020 DMAIN <0000> osmo-trx.cpp:532 [tid=140667439762688] – Transceiver active with 1 channel(s)
Mon Jul 20 02:02:13 2020 DDEV <0005> LMSDevice.cpp:1010 [tid=140667439762688][chan=0] Setting Rx Freq to 1.711e+09 Hz
Mon Jul 20 02:02:13 2020 DDEV <0005> LMSDevice.cpp:980 [tid=140667439762688][chan=0] Setting Tx Freq to 1.806e+09 Hz
Mon Jul 20 02:02:13 2020 DTRXCTRL <0002> Transceiver.cpp:967 [tid=140667439762688] Changing TSC from 0 to 7
Mon Jul 20 02:02:13 2020 DMAIN <0000> Transceiver.cpp:297 [tid=140667439762688] Starting the transceiver
Mon Jul 20 02:02:13 2020 DDEV <0005> LMSDevice.cpp:555 [tid=140667439762688][chan=0] Setting RX gain to 36.5 dB
Mon Jul 20 02:02:13 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667439762688] Rx LPF min bandwidth is 4MHz when TIA gain is set to -12 dB
Mon Jul 20 02:02:17 2020 DMAIN <0000> Transceiver.cpp:293 [tid=140667439762688] Transceiver already running
Mon Jul 20 02:02:17 2020 DDEV <0005> LMSDevice.cpp:555 [tid=140667439762688][chan=0] Setting RX gain to 1 dB
Mon Jul 20 02:02:17 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:02:17 2020 DTRXCLK <0001> Transceiver.cpp:1127 [tid=140667368752896] Sending CLOCK indications
Mon Jul 20 02:02:17 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (0 -> 1)
Mon Jul 20 02:02:17 2020 DDEV <0005> LMSDevice.cpp:578 [tid=140667439762688][chan=0] Setting TX gain to 66 dB (~-11.6 dBm)
Mon Jul 20 02:02:27 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:02:27 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (1 -> 2)
Mon Jul 20 02:02:48 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:02:48 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (2 -> 3)
Mon Jul 20 02:03:35 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:03:35 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (3 -> 4)
Mon Jul 20 02:03:44 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:03:44 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (4 -> 5)
Mon Jul 20 02:03:55 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:03:55 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (5 -> 6)
Mon Jul 20 02:03:59 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:03:59 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (6 -> 7)
Mon Jul 20 02:04:31 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:04:31 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (7 -> 8)
Mon Jul 20 02:04:55 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:04:55 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (8 -> 9)
Mon Jul 20 02:05:00 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:05:00 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (9 -> 10)
Mon Jul 20 02:05:16 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:05:16 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (10 -> 11)
Mon Jul 20 02:05:25 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:05:25 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (11 -> 12)
Mon Jul 20 02:05:40 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:05:40 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (12 -> 13)
Mon Jul 20 02:05:48 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:05:48 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (13 -> 14)
Mon Jul 20 02:06:00 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:06:00 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (14 -> 15)
Mon Jul 20 02:06:26 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:06:26 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (15 -> 16)
Mon Jul 20 02:06:43 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:06:43 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (16 -> 17)
Mon Jul 20 02:06:50 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:06:50 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (17 -> 18)
Mon Jul 20 02:06:56 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:06:56 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (18 -> 19)
Mon Jul 20 02:07:02 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:07:02 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (19 -> 20)
Mon Jul 20 02:07:07 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:07:07 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (20 -> 21)
Mon Jul 20 02:09:23 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:09:23 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (21 -> 22)
Mon Jul 20 02:10:25 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:10:25 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (22 -> 23)
Mon Jul 20 02:10:36 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:10:36 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (23 -> 24)
Mon Jul 20 02:10:50 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:10:50 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (24 -> 25)
Mon Jul 20 02:10:57 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:10:57 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (25 -> 26)
Mon Jul 20 02:11:06 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:11:06 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (26 -> 27)
Mon Jul 20 02:11:12 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:11:12 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (27 -> 28)
Mon Jul 20 02:11:24 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:11:24 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (28 -> 29)
Mon Jul 20 02:11:32 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:11:32 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (29 -> 30)
Mon Jul 20 02:12:05 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:12:05 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (30 -> 31)
Mon Jul 20 02:13:50 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:13:50 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (31 -> 32)
Mon Jul 20 02:13:59 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:13:59 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (32 -> 33)
Mon Jul 20 02:14:29 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:14:29 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (33 -> 34)
Mon Jul 20 02:14:30 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:14:30 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (34 -> 35)
Mon Jul 20 02:14:31 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:14:31 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (35 -> 36)
Mon Jul 20 02:14:31 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (36 -> 37)
Mon Jul 20 02:14:31 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (37 -> 38)
Mon Jul 20 02:15:35 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:15:35 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (38 -> 39)
Mon Jul 20 02:16:12 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:16:12 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (39 -> 40)
Mon Jul 20 02:16:58 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:16:58 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (40 -> 41)
Mon Jul 20 02:17:30 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:17:30 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (41 -> 42)
Mon Jul 20 02:17:56 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:17:56 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (42 -> 43)
Mon Jul 20 02:18:13 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:18:13 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (43 -> 44)
Mon Jul 20 02:19:02 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:19:02 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (44 -> 45)
Mon Jul 20 02:23:13 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667402323712] L
Mon Jul 20 02:23:13 2020 DDEV <0005> LMSDevice.cpp:919 [tid=140667377145600][chan=0] Tx Dropped packets by HW! (45 -> 46)
^Csignal 2 received
shutting down
Mon Jul 20 02:23:33 2020 DMAIN <0000> osmo-trx.cpp:489 [tid=140667439762688] Shutting down transceiver…
Mon Jul 20 02:23:33 2020 DMAIN <0000> Transceiver.cpp:355 [tid=140667439762688] Stopping the transceiver
Mon Jul 20 02:23:34 2020 DDEVDRV <0006> LMSDevice.cpp:196 [tid=140667385538304] popping from TX, samples popped 900/1020
Mon Jul 20 02:23:34 2020 DMAIN <0000> Transceiver.cpp:381 [tid=140667439762688] Transceiver stopped
