Been playing with the LimeSDRMini for a little bit now, haven’t gotten serious into it until the last month. I’m having trouble using it with various different programs and “resetting” it to a decent default state when it gets plugged back in. As an example, a while back I was playing with osmo-trx-lms and it seemed to have worked fine. A week later it after using various programs like gqrx or attempting to use rtl_443 with it, osmo-trx-lms seems to be unable to set the VCTCXO and unable to calibrate the TX. LimeQuickTest looks fine to me. When using with GQRX however now I seem to be unable to pick up even basic FM and decode RDS without jacking the TIA, LNA and PGA settings extremely high.
Any ideas and advice on why osmo-trx-lms is unable to make the right changes?
—LimeQuickTest–
$ LimeQuickTest
->Start time: Mon Apr 15 00:44:16 2019
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3AD5B2511398
Serial Number: 1D3AD5B2511398
->REF clock test
Test results: 3542; 16743; 29936 - PASSED
Results : 6710998 (min); 6711153 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 02 18 12 02 18 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-13.2 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-14.7 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 2.38 seconds
---- osmo-trx-lms.cfg —
log stderr
logging filter all 1
logging color 1
logging print category 1
logging timestamp 1
logging print file basename
logging level set-all info
line vty
no login
trx
bind-ip 127.0.0.1
remote-ip 127.0.0.1
base-port 5700
egprs disable
tx-sps 4
rx-sps 4
rt-prio 18
chan 0
tx-path BAND1
rx-path LNAW
— Output —
sudo osmo-trx-lms -C ./osmo-trx-limesdr.cfg
Info: SSE3 support compiled in and supported by CPU
Info: SSE4.1 support compiled in and supported by CPU
Mon Apr 15 00:58:17 2019 DLGLOBAL <0004> telnet_interface.c:104 Available via telnet 127.0.0.1 4237
Mon Apr 15 00:58:17 2019 DLCTRL <000b> control_if.c:911 CTRL at 127.0.0.1 4236
Mon Apr 15 00:58:17 2019 DMAIN <0000> osmo-trx.cpp:431 [tid=140144586563456] Config Settings
Log Level… 0
Device args…
TRX Base Port… 5700
TRX Address… 127.0.0.1
GSM BTS Address… 127.0.0.1
Channels… 1
Tx Samples-per-Symbol… 4
Rx Samples-per-Symbol… 4
EDGE support… 0
Extended RACH support… 0
Reference… 0
C0 Filler Table… 1
Multi-Carrier… 0
Tuning offset… 0
RSSI to dBm offset… 0
Swap channels… 0
Tx Antennas… ‘BAND1’
Rx Antennas… ‘LNAW’
Mon Apr 15 00:58:17 2019 DMAIN <0000> osmo-trx.cpp:387 [tid=140144586563456] Setting SCHED_RR priority 18
Mon Apr 15 00:58:17 2019 DDEV <0002> LMSDevice.cpp:68 [tid=140144586563456] creating LMS device…
Mon Apr 15 00:58:17 2019 DDEV <0002> LMSDevice.cpp:156 [tid=140144586563456] Opening LMS device…
Mon Apr 15 00:58:17 2019 DDEV <0002> LMSDevice.cpp:162 [tid=140144586563456] Devices found: 1
Mon Apr 15 00:58:17 2019 DDEV <0002> LMSDevice.cpp:172 [tid=140144586563456] Device [0]: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3AD5B2511398
Mon Apr 15 00:58:17 2019 DDEV <0002> LMSDevice.cpp:181 [tid=140144586563456] Using device[0]
Mon Apr 15 00:58:17 2019 DLMS <0003> LMSDevice.cpp:102 [tid=140144586563456] Reference clock 40.00 MHz
Mon Apr 15 00:58:17 2019 DDEV <0002> LMSDevice.cpp:191 [tid=140144586563456] Init LMS device
Mon Apr 15 00:58:18 2019 DDEV <0002> LMSDevice.cpp:113 [tid=140144586563456] Sample Rate: Min=100000 Max=3.072e+07 Step=0
Mon Apr 15 00:58:18 2019 DDEV <0002> LMSDevice.cpp:201 [tid=140144586563456] Setting sample rate to 1.08333e+06 4
Mon Apr 15 00:58:18 2019 DDEV <0002> LMSDevice.cpp:207 [tid=140144586563456] Sample Rate: Host=1.08333e+06 RF=3.46667e+07
Mon Apr 15 00:58:18 2019 DDEV <0002> LMSDevice.cpp:214 [tid=140144586563456] Setting Internal clock reference
Mon Apr 15 00:58:18 2019 DDEV <0002> LMSDevice.cpp:218 [tid=140144586563456] Setting VCTCXO to 65535
Mon Apr 15 00:58:18 2019 DLMS <0003> LMSDevice.cpp:102 [tid=140144586563456] Error
Mon Apr 15 00:58:18 2019 DDEV <0002> LMSDevice.cpp:113 [tid=140144586563456] LPFBWRange Rx: Min=1.4001e+06 Max=1.3e+08 Step=0
Mon Apr 15 00:58:18 2019 DDEV <0002> LMSDevice.cpp:113 [tid=140144586563456] LPFBWRange Tx: Min=1.4001e+06 Max=1.3e+08 Step=0
Mon Apr 15 00:58:18 2019 DDEV <0002> LMSDevice.cpp:242 [tid=140144586563456] LPFBW: Rx=1.4001e+06 Tx=5.2e+06
Mon Apr 15 00:58:18 2019 DMAIN <0000> LMSDevice.cpp:203 [tid=140144586563456] Antennas configured successfully
Mon Apr 15 00:58:18 2019 DDEV <0002> LMSDevice.cpp:251 [tid=140144586563456] Setting LPFBW chan 0
Mon Apr 15 00:58:21 2019 DLMS <0003> LMSDevice.cpp:102 [tid=140144586563456] RX LPF configured
Mon Apr 15 00:58:21 2019 DLMS <0003> LMSDevice.cpp:102 [tid=140144586563456] Filter calibrated. Filter order-4th, filter bandwidth set to 5.2 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
Mon Apr 15 00:58:21 2019 DLMS <0003> LMSDevice.cpp:102 [tid=140144586563456] TX LPF configured
Mon Apr 15 00:58:21 2019 DDEV <0002> LMSDevice.cpp:256 [tid=140144586563456] Calibrating chan 0
Mon Apr 15 00:58:21 2019 DLMS <0003> LMSDevice.cpp:102 [tid=140144586563456] Rx calibration finished
Mon Apr 15 00:58:21 2019 DLMS <0003> LMSDevice.cpp:102 [tid=140144586563456] Tx Calibration: MCU error 4 (SXT tune failed)
Mon Apr 15 00:58:21 2019 DMAIN <0000> Threads.cpp:116 [tid=140144586798848] Thread 140144586798848 (task 15191) set name: CtrlService0
Mon Apr 15 00:58:21 2019 DMAIN <0000> osmo-trx.cpp:479 [tid=140144586563456] – Transceiver active with 1 channel(s)
