ERROR Writte 64 Byte Failled LimeSDRmini
How I can repair my LimeSDR mini?
nano@nano-GP62-2QE:~$ LimeQuickTest
->Start time: Thu Mar 28 04:54:08 2019
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3AC779327FE0
Serial Number: 1D3AC779327FE0
->REF clock test
Test results: 59896; 7557; 20754 - PASSED
Results : 6710976 (min); 6711142 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 02 17 12 02 17 02
->FPGA EEPROM Test PASSED
Read(64 bytes) failed
Write(64 bytes) failed
->LMS7002M Test FAILED
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 0.84 seconds
If you are on MacOS, unplug and replug. This is typical of an improperly shut down connection to it, because of an incompatibility between libusb and the FT601 USB chip. There is a discussion a few weeks ago on this group that I started about how to patch libusb to fix it.
If not MacOS, I have no idea.
Not Mac, openSUSE
so where is this patch ? or where is this discussion?
had to dig back and find it. here is the discussion:
the patch is do-it-yourself with an editor, since it is just a single line to comment out of the source code. This was with libusb 1.0.22 source. After rebuilding libusb, make sure you get LimeSuite to use the updated version.
