Below is trying with the stock cable, and 2 other cables from Amazon. Same result when plugged into a 7.5v power supply. Same results no matter what I do, unless I reflash it.
root@Dhalsim:~# LimeQuickTest
->Start time: Mon Sep 16 20:30:42 2019
Read(64 bytes) failed
Gateware version mismatch!
Expected gateware version 2, revision 17
Lime Suite - Myriad-RF Wiki
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009060B00463617
Serial Number: 0009060B00463617
->FX3 GPIF clock test
->FX3 GPIF clock test FAILED
->Si5351C test
FAILED
FAILED
->ADF4002 Test
FAILED
->Clock Network Test FAILED
->Read data: 10 0C 1D 10 0C 1D 02
->FPGA EEPROM Test PASSED
SPI_write() failed
SPI_write() failed
SPI_write() failed
->LMS7002M Test FAILED
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 0.22 seconds
->Start time: Mon Sep 16 20:31:07 2019
Write(64 bytes) failed
->Si5351C test
FAILED
FAILED
->ADF4002 Test
FAILED
SPI_write() failed
SPI_write() failed
SPI_write() failed
Elapsed time: 3.70 seconds
->Start time: Mon Sep 16 20:31:13 2019
->Si5351C test
FAILED
FAILED
->ADF4002 Test
FAILED
SPI_write() failed
SPI_write() failed
SPI_write() failed
root@Dhalsim:~#
The following is after trying to flash using LimeUtil…
root@Dhalsim:~# LimeUtil -fpga=/home/ramsin/LimeSDR-USB_HW_1.4_r2.21.rbf
Connected to [LimeSDR-USB [USB 3.0] 9060B00463617]
[100%] 580050/580050 Bytes programming: completed
FPGA boot from FLASH completed!
->Start time: Mon Sep 16 20:37:40 2019
->Si5351C test
FAILED
FAILED
->ADF4002 Test
FAILED
SPI_write() failed
SPI_write() failed
SPI_write() failed
Elapsed time: 4.08 seconds
root@Dhalsim:~#
