Hi …
recently , I purchased your Myriad-RF board (STREAM) , and I will connect this board with xilinux borad …
can you please give me guide how to start ??
I hope to tell me if configuration will be available for ubuntu O.S
thanks
Hi …
thanks
Hi Mohammed,
Since STREAM is an FPGA development board, I’m not sure how you intend to connect it to another one and you would need to work out the design and supporting software yourself.
Drivers are being worked on that will enable you to use STREAM together with either the Myriad-RF 1 or UNITE7002 board, to give you a USB 3.0 attached SDR peripheral. This configuration would be supported under Ubuntu.
Regards,
Andrew
