Hello, I have a problem with using STREAM board with Myriad-RF(LMS6002D).
I can’t find the exact Lime Suite GUI tool for running LMS6002D.
I’m using LMS7002 software to connect to STREAM board. But I think it’s not the software for LMS6002D. Is there any solution? Thanks.
You are correct, in that Lime Suite does not currently provide any support for LMS6002D-based hardware. There are plans to add support, but it’s not a small undertaking and it’s a question of finding time.
At present LMS6002D boards must use the legacy “LMS Suite” software, which was produced in different versions to support different hardware platforms. The STREAM + Myriad-RF 1 software can be found here:
