I’ve just got a LimeSDR-mini to learn about GSM and DBTV in a practical way, having a STEM background.
Now, I’m trying to view the spectrum of a 433MHz transmitter. I’ve set up the frequency in LimeSuiteGUI software, clicked Calculate and then Tune and lastly opened the FFT Viewer which shows an empty graph.
If I try running the GUI->Chip command, I always get the following error:
WARNING: SetPllFrequency: error configuring phase
ERROR: LML RX phase search FAIL
while in the terminal
warning [darwin_abort_transfers] aborting all transactions on interface 1 pipe 4
I’m using OSX, is the unit faulty? How can I get it to work?
Thank you
@Zack @IgnasJ could you advise, please.
Zack
3 December 2019 06:07
3
Hi @Anelito ,
Execute LimeQuickTest and post log file here, please.
Here it is
$ LimeQuickTest --no-gui
->Start time: Tue Dec 3 10:55:03 2019
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D49835FC4C1AB
Serial Number: 1D49835FC4C1AB
->REF clock test
Test results: 41556; 54753; 2414 - PASSED
Results : 6711044 (min); 6711211 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 0C 14 12 0C 14 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-13.0 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-12.8 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 4.99 seconds
Apparently all tests are ok, yet there is no signal on the 433MHz band despite using a low-power transmitter next to the LimeSDR mini.
Zack
3 December 2019 10:20
5
Board looks OK.
What LimeSuiteGUI version do you use? Make sure it is the latest one.
I am using the stable release from GitHub
