XTRX v.1.3 sampling rate
I would like to use the XTRX v.1.3 with 2 Rx and 1 Tx. The maximum sampling rates for Rx is a little confusing. In this link: Lime Microsystems | LimeSDR XTRX, it says for SISO, the sampling rate is 120 MSps with a bandwidth of 120MHz (I assume that there is a filter that is configurable by the software on the front-end of the SDR), and for MIMO is 90MSps. So for 2 Rx, 1 Tx, is this 90MSps total (so 30MSps per channel Rx and Tx), or 90MSps each? If I don’t use Tx, and only 2 Rx, what would the sampling rate per channel be?
The other confusing issue is that, at this link: LimeSDR XTRX v1.3 Board — LimeSDR XTRX Boards 23.01 documentation, it says the sampling rate is 30.72MSps for MIMO.
Hi, the XTRX maximum sampling rates for each direction are 122.88MSps for SISO, and 61.44MSps for MIMO.
In your case 2Rx+1Tx, or just 2Rx is MIMO.
Hi Ricardas,
Could you please clarify the source of these limits?
So 90MSps in MIMO is just a markerting? I can count only on 61.44 per channel?
