Type A USB 3.0 plug
I damaged my plug & need a new one. I have scoured the web & am unable to find one that will ship to the USA.
Can I purchase one from you?
BOM comment USB3.0_MALE
Footprint USB3A_SM
Manufacturer Global Connector Technology
MPN USB1065-30-A
Supplier Farnell 2443106
Description USB-A USB 3.0 SuperSpeed plug, 9-position, surface mount, right angle, horizontal
Thank you,
Ed
Hi Ed,
I’m afraid we don’t carry spares. Whenever boards are made our manufacturing partner orders the exact bill of materials required. If you cannot find that part, I’d be surprised if there is not a footprint compatible one which you could order from the likes of DigiKey or Mouser.
What I found with Claude’s assistance:
The footprint is a single row of 9 SMT pads at 1.0 mm pitch, with two plated shell slots 11.70 mm apart and two 1.1 mm NPTH pegs 4.50 mm apart. Now I’ll compare that against candidate parts.
The replacement I’d use is Würth Elektronik 692112030100 (WR-COM USB 3.0 Type-A plug, horizontal SMT). It should drop straight onto the existing J15 footprint without any PCB changes.
I compared Würth’s recommended land pattern with the J15 pad data in LimeSDR-USB v1.4’s PCB export:
Feature LimeSDR v1.4 J15 Würth 692112030100
Signal pads 9 pads in one row, 1.00 mm pitch, 0.70 × 1.80 mm Same
Pin order along the row 9-1-8-2-7-3-6-4-5 Same order and same orientation
Locating pegs Ø1.10 mm holes, 4.50 mm apart Same
Shell tabs 1.0 × 2.5 mm plated slots, 1.6 × 4.0 mm copper, 11.70 mm apart Same slot and copper; tabs about 11.7 mm apart
Pad row to peg line 2.40 mm 2.45 mm
The 0.05 mm difference in pad-row position is small against a 1.8 mm-long pad, so it shouldn’t affect soldering. The Würth part also has the same 4.5 mm profile as the GCT part.
Availability: Mouser lists 7,365 in stock as 710-692112030100, at $3.20 for one or $2.39 each at 100. Mouser’s page was showing an error near the buy button, so check it in your cart. Farnell (1861258) has no stock right now and quotes a 13-week lead time.
The GCT USB1065-30-A was declared end-of-life in 2016, and GCT doesn’t make a USB 3.0 Type-A plug anymore. LCSC’s results were almost all receptacles, and I couldn’t search DigiKey because of its bot check. There may be cheaper Asian-brand equivalents, but I didn’t find one I could verify.
Before you order in volume, check the Würth mechanical drawing against your board outline to confirm how far the plug sticks out past the board edge. I didn’t check the board outline.
Sources:
