Finally got sdrangel to RX in Debian but gnuradio will not cooperate.
This is what happens.
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.10
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy soapy redpitaya
[INFO] Make connection: ‘USB 2.0 (LimeSDR Mini)’
Claimed Interface
[INFO] Device name: uLimeSDR
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
LMS7002M values cache at /root/.limesuite/LMS7002M_cache_values.db
[INFO] Ver=7, Rev=1, Mask=1
CGEN: Freq=80 MHz, VCO=2.4 GHz, INT=77, FRAC=131072, DIV_OUTCH_CGEN=14
[INFO] SoapyLMS7::setFrequency(Rx, 0, BB, 0 MHz)
[INFO] SoapyLMS7::setFrequency(Tx, 0, BB, 0 MHz)
[INFO] SoapyLMS7::setAntenna(Tx, 0, BAND1)
[INFO] SoapyLMS7::setGain(Rx, 0, PGA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 0, LNA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 0, TIA, 0 dB)
[INFO] SoapyLMS7::setGain(Tx, 0, PAD, -50 dB)
[INFO] SoapyLMS7::setSampleRate(Rx, 0, 10 MHz), CGEN=80 MHz, ADC=20 MHz, decim=2
[ERROR] SetFrequencyCGEN(80 MHz) failed:
INT: 77 FRAC: 131072 DIV_OUTCH_CGEN: 14
VCO: 2400 MHz RefClk: 30.72 MHz
TuneVCO(CGEN) - VCO too low
Connection_uLimeSDR::UpdateExternalDataRate(tx=20MHz, rx=10MHz)
----- FPGA PLL #0 CONFIG -----
M=112, N=7, Fvco=640.000 MHz
C0=16, Fout=40.000 MHz, CNT_IND=2, nSteps=0, phaseShift=0.0
C1=16, Fout=40.000 MHz, CNT_IND=3, nSteps=32, phaseShift=90.0
C2=32, Fout=20.000 MHz, CNT_IND=4, nSteps=0, phaseShift=0.0
C3=32, Fout=20.000 MHz, CNT_IND=5, nSteps=64, phaseShift=90.0
[INFO] SoapyLMS7::setSampleRate(Tx, 0, 10 MHz), CGEN=80 MHz, DAC=20 MHz, interp=2
Connection_uLimeSDR::UpdateExternalDataRate(tx=10MHz, rx=10MHz)
M=93, N=3, Fvco=620.000 MHz
C0=31, Fout=20.000 MHz, CNT_IND=2, nSteps=0, phaseShift=0.0
C1=31, Fout=20.000 MHz, CNT_IND=3, nSteps=62, phaseShift=90.0
C2=31, Fout=20.000 MHz, CNT_IND=4, nSteps=0, phaseShift=0.0
C3=31, Fout=20.000 MHz, CNT_IND=5, nSteps=62, phaseShift=90.0
[INFO] SoapyLMS7::setBandwidth(Rx, 0, 30 MHz)
CGEN: Freq=332.56 MHz, VCO=2.66048 GHz, INT=85, FRAC=633514, DIV_OUTCH_CGEN=3
[ERROR] setBandwidth(Rx, 0, 30 MHz) Failed - SetFrequencyCGEN(332.56 MHz) failed:
INT: 85 FRAC: 633514 DIV_OUTCH_CGEN: 3
VCO: 2660.48 MHz RefClk: 30.72 MHz
FATAL: SetFrequencyCGEN(332.56 MHz) failed:
