Hi everyone!
I have been fiddling with my brand new LimeSDR and have encountered a strange situation.
I was testing if wire formats affected performance, so I took the SoapySDRUtil tool and modified it so I could change the wire format between CS16 and CF32. Strangely, even tough CS16 should take half the bandwidth, when I run the program with a rate of 3 megasamples the “usbtop” tool reports 12 MBps usage for both wire formats.
After that I took the “singleRX” code from LimeSuite and did the same, testing with LMS_FMT_F32, LMS_FMT_I16 and LMS_FMT_I12 and 1 Megasample rate, getting results from the “linkRate” value extracted from the stream status and the “usbtop” command.
For F32 format -> linkRate: 4MBps, usbtop: 4 MBps
For S16 format -> linkRate: 4MBps, usbtop: 4 MBps
For I12 format -> linkRate: 3MBps, usbtop: 3 MBps
For I12 the results make sense, since 12 bytes are 1.5 Bytes, the same goes for S16 (2*2bytes). But for F32 shouldn’t it be 8 MBps?
I am using the following code, and only changing the format and the buffer type
//Streaming Setup
//Initialize stream
lms_stream_t streamId;
streamId.channel = 0; //channel number
streamId.fifoSize = 1024 * 1024; //fifo size in samples
streamId.throughputVsLatency = 1.0; //optimize for max throughput
streamId.isTx = false; //RX channel
//streamId.dataFmt = lms_stream_t::LMS_FMT_F32; //32-bit floats
streamId.dataFmt = lms_stream_t::LMS_FMT_I16;
//streamId.dataFmt = lms_stream_t::LMS_FMT_I12; //12-bit ints
if (LMS_SetupStream(device, &streamId) != 0)
error();
//Data buffers
const int bufersize = 10000; //complex samples per buffer
//float buffer[bufersize * 2]; //must hold I+Q values of each sample
short buffer[bufersize * 2];
//Start streaming
LMS_StartStream(&streamId);
auto t2 = t1;
while (chrono::high_resolution_clock::now() - t1 < chrono::seconds(10)) //run for 10 seconds
int samplesRead;
//Receive samples
samplesRead = LMS_RecvStream(&streamId, buffer, bufersize, NULL, 1000);
//I and Q samples are interleaved in buffer: IQIQIQ...
//Print stats (once per second)
lms_stream_status_t status;
//Get stream status
LMS_GetStreamStatus(&streamId, &status);
cout << "RX data rate: " << status.linkRate / 1e6 << " MB/s\n"; //link data rate
cout << "RX sample rate: " << status.sampleRate / 1e6 << " MSamples/s\n"; //link data rate
cout << "RX fifo: " << 100 * status.fifoFilledCount / status.fifoSize << "%" << endl; //percentage of FIFO filled
//Stop streaming
LMS_StopStream(&streamId); //stream is stopped but can be started again with LMS_StartStream()
LMS_DestroyStream(device, &streamId); //stream is deallocated and can no longer be used
//Close device
LMS_Close(device);
return 0;
Thanks for the help!
Kind regards,
Aridane
