Data format of samples
Using the c++ limesuite library
Since the LimeSDR uses a 12 bit ADC, is there any difference in the amount of information that can be represented between the LMS_FMT_I12 and LMS_FMT_I16 data type?
I understand that LMS_FMT_I12 is used in the hardware with 3 bytes representing 1 IQ sample and the LMS_FMT_I16 uses 4 bytes to represent 1 IQ sample as shown here. So what is the advantage of using LMS_FMT_I16 instead of LMS_FMT_I12?
The F32 outputs normalized values [-1:1] of the LMS_FMT_I16 data type. How does the software do this? Is it as simple as taking a sample from the I16 format and dividing it by 0x7fff?
One for @Zack I think.
Hello @kohlsn,
Exactly. You can find more details in the Read/Write functions implementation (LimeSuite/src/protocols/Streamer.cpp at master · myriadrf/LimeSuite · GitHub) :
if(config.format == StreamConfig::FMT_FLOAT32 && !config.isTx)
    //in place conversion
    complex16_t* ptr = (complex16_t*)samples;
    int16_t* samplesShort = (int16_t*)samples;
    float* samplesFloat = (float*)samples;
    popped = fifo->pop_samples(ptr, count, &meta->timestamp, timeout_ms);
    for(int i=2*popped-1; i>=0; --i)
        samplesFloat[i] = (float)samplesShort[i]/32767.0f;
Some hints can be found in comments (LimeSuite/src/protocols/Streamer.h at master · myriadrf/LimeSuite · GitHub):
Choosing a compressed format can decrease link use
at the expense of additional processing on the PC.
It’s difficult to say for sure, but according to the comments mentioned above both formats contain the same data and LMS_FMT_I16 is just a “16-bit container” for “12-bit values”.
I’m not sure in the last statement, so it would be great to get the correct answer from @Zack.
You can send I and Q sample (12 bits each) using 3 or 4 bytes:
  1. When sending using 4 bytes each of I and Q sample is send using 2 bytes, hence 4 bits not used i.e. link (USB/PCIe) throughput waste.
  2. When sending using 3 bytes there are all the bits of 3 bytes occupied. Hence no link throughput waste, but there is more processing involved at host side for I and Q samples unscrambling.
Thank you, that makes a lot of sense.
I did some testing with the data types.
I found that I can normalize the LMS_FMT_I16 data type to produce the same result as using the LMS_FMT_F32.
However, when I normalize the LMS_FMT_I12 data type I get a result of a increased delay between the transmitter and receiver. Is this because of the I and Q unscrambling? Data being truncated? Or some other reason?
The LMS_FMT_I16 data type is just the LMS_FMT_I12 data type shifted 4 bits so that the least significant 4 bits are 0. If this is the case wouldn’t it make more sense to normalize the LMS_FMT_I16 to LMS_FMT_F32 by dividing the samples by 32752 (0x7FF0) and not 32767 (0x7FFF)?
