I am using USB 3 Connection. Following is the API Code where I have used the basixRX.cpp for reading and writing the samples to a buffer and then process the samples received samples using concepts of WiFi PHY layer processing:
@file basicRX.cpp
@author Lime Microsystems (www.limemicro.com)
@brief minimal RX example
#include “lime/LimeSuite.h”
#include
#include
#include
#include <boost/date_time/posix_time/posix_time.hpp>
#include <boost/date_time/gregorian/gregorian.hpp>
#include <boost/program_options.hpp>
#include <fun_ofdm/receiver.h>
#include <fun_ofdm/receiver_chain.h>
#ifdef USE_GNU_PLOT
#include “gnuPlotPipe.h”
#endif
using namespace std;
lms_device_t* device = NULL;
int rx_count = 0;
int error()
if (device != NULL)
LMS_Close(device);
exit(-1);
std::ofstream myfile(“wifi_rx.txt”, std::fstream::out | std::ofstream::trunc );
//Find devices
int n;
lms_info_str_t list[8]; //should be large enough to hold all detected devices
if ((n = LMS_GetDeviceList(list)) < 0) //NULL can be passed to only get number of devices
error();
cout << "Devices found: " << n << endl; //print number of devices
if (n < 1)
return -1;
//open the first device
error();
//Use LMS_LoadConfig(device, "/path/to/file.ini") to load config from INI
//if (LMS_Init(device) != 0)
//error();
//Enable RX channel
//Channels are numbered starting at 0
error();
//Set center frequency to 800 MHz
if (LMS_SetLOFrequency(device, LMS_CH_RX, 0, 2472e6) != 0)
error();
//Set sample rate to 8 MHz, ask to use 2x oversampling in RF
//This set sampling rate for all channels
if (LMS_SetSampleRate(device, 20e6, 1) != 0)
error();
//Configure LPF, bandwidth 8 MHz
if (LMS_SetLPFBW(device, LMS_CH_RX, 0, 20e6) != 0)
error();
//Set RX gain
if (LMS_SetNormalizedGain(device, LMS_CH_RX, 0, 0.95) != 0)
error();
//Print RX gain
float_type gain; //normalized gain
if (LMS_GetNormalizedGain(device, LMS_CH_RX, 0, &gain) != 0)
error();
cout << "Normalized RX Gain: " << gain << endl;
unsigned int gaindB; //gain in dB
if (LMS_GetGaindB(device, LMS_CH_RX, 0, &gaindB) != 0)
error();
cout << "RX Gain: " << gaindB << " dB" << endl;
//Enable test signal generation
//To receive data from RF, remove this line or change signal to LMS_TESTSIG_NONE
//if (LMS_SetTestSignal(device, LMS_CH_RX, 0, LMS_TESTSIG_NCODIV8, 0, 0) != 0)
// error();
//Streaming Setup
//Initialize stream
lms_stream_t streamId; //stream structure
streamId.channel = 0; //channel number
streamId.fifoSize = 2048 * 2048; //fifo size in samples
streamId.throughputVsLatency = 1.0; //optimize for max throughput
streamId.isTx = false; //RX channel
streamId.dataFmt = lms_stream_t::LMS_FMT_F32; //12-bit integers
if (LMS_SetupStream(device, &streamId) != 0)
error();
//Initialize data buffers
const int sampleCnt = 1000000; //complex samples per buffer
//int16_t buffer[sampleCnt * 2]; //buffer to hold complex values (2*samples))
float buffer[sampleCnt * 2]; //buffer to hold complex values (2*samples))
std::vector<std::complex<double>> complex_buffer;
//Start streaming
LMS_StartStream(&streamId);
//Streaming
#ifdef USE_GNU_PLOT
GNUPlotPipe gp;
gp.write(“set size square\n set xrange[-2050:2050]\n set yrange[-2050:2050]\n”);
#endif
int count_samples=0;
int count = 0;
auto t2=t1;
int alp =0;
while (chrono::high_resolution_clock::now() - t1 < chrono::seconds(10)) //run for 5 seconds
//Receive samples
int samplesRead = LMS_RecvStream(&streamId, buffer, sampleCnt, NULL, 1000);
//printf("Received %d samples\n", samplesRead);
count_samples += samplesRead;
// PROCESSING RECEIVED SAMPLES
//I and Q samples are interleaved in buffer: IQIQIQ…
complex_buffer.clear();
for(int i=0;i<sampleCnt;i++)
complex_buffer.push_back({buffer[2i],buffer[(2i) +1]});
fun::receiver_chain * receiver1 = new fun::receiver_chain();
int chunk_size =65536;
for(int x = 0; x < complex_buffer.size(); x += chunk_size)
int start = x;
int end = x + chunk_size;
if(end > complex_buffer.size()) end = complex_buffer.size();
std::vector<std::complex<double> > chunk(&complex_buffer[start], &complex_buffer[end]);
std::vector<std::vector<unsigned char> > rec_frames = receiver1->process_samples(chunk);
count += rec_frames.size();
if(rec_frames.size() != 0){
std::cout<<rec_frames.size()<<" rec_frames"<<std::endl;
if(rec_frames.size())
for(int i = 0; i < rec_frames.size(); i++)
alp = alp + rec_frames[i].size();
for(int j = 0; j < rec_frames[i].size(); j++)
myfile<<rec_frames[i][j];
myfile<<"\n";
#ifdef USE_GNU_PLOT
//Plot samples
gp.write("plot '-' with points\n");
for (int j = 0; j < samplesRead; ++j)
gp.writef("%i %i\n", buffer[2 * j], buffer[2 * j + 1]);
gp.write("e\n");
gp.flush();
#endif
myfile.close();
printf("Received %d samples\n", count_samples);
printf("Sample Rate %d MSamples/s \n", count_samples/(10*1e6));
printf("Received %i packets\n", count);
printf("total no. of chars in rec_frames - %i",alp);
//Stop streaming
LMS_StopStream(&streamId); //stream is stopped but can be started again with LMS_StartStream()
LMS_DestroyStream(device, &streamId); //stream is deallocated and can no longer be used
//Close device
LMS_Close(device);
return 0;
