Tried to integrate it to the master gateware but failed to find a suitable spot on the RX path. One potential location was right after the DDR interface, but this requires rounding the filter output to 12 bits; and as it turns out, it is impossible to remove the DC-offset with 12 bits, at least 16 bits should be kept.
Plan B was to remove everything from the RX path and just stream 16-bit outputs from the filter to the host. This works, but breaks the time-stamping and needs a custom LimeSuite.
So, if anyone wants to try this out:
@gasparka
I was unable to open LimeSDR-Mini_lms7_trx.pqf from gitrev 1365e10 forward on the dc_removal branch. It looks like the error was caused by a mismatch of Quartus versions. Looks like you are using version 18.0.0 Lite Edition. When I downloaded that version I still got an error message, but at least the project opened.
Error (125048): Error reading Quartus Prime Settings File C:/dc_removal_18.0/LimeSDR-Mini_GW/LimeSDR-Mini_lms7_trx/LimeSDR-Mini_lms7_trx.qsf, line 109
Info (125063): set_global_assignment -name TIMING_ANALYZER_MULTICORNER_ANALYSIS ON
this same error occurs on line 110 of uLimeSDR_lms7_trx.qsf
I downloaded the project directly from GitHub (rev 3da…) and had no problems opening/compiling it under Windows 10 with Quartus 18.0 .
Unfortunately i don’t have access to a Windows 7 machine nor Quartus 17.
Try to comment out the offending lines and see if it works.
I also tried compiling a clean Github download of this project with Quartus 18.0 and I agree that the error does not happen.
It happens with the older versions of Quartus; the versions that Myriad appears to be using.
Yes, removing the offending line from both files works.
