Hi @IgnasJ,
I am using Lime Suite API for Development of custom product with LMS7002M chip . I was trying to tune the RX filter bandwidth to different bandwidths. The function returned correct value 0 as it was tuned . However, on observing the output I see a noisy spectrum. This is a random issue as sometimes a particular BW setting works and sometimes it doesn’t.
Should I add delay after the SetLPFBW bandwidth function ?
Hi @kishores,
Do you have a chance to share your source code?
Sure @Zack .
enum ARG_LIST{
TYPE=1,
VALUE=2,
CHAN=3,
enum ERRORS{
NO_DEV=-1,
NOT_OPEN=-2,
ERROR_ARG=-3
int ERROR_STAT = 0;
lms_device_t* device = NULL;
using namespace std;
using namespace lime;
void setValue(char** argv){
string type = argv[TYPE];
if(type == "CGEN"){
double cgen=atof(argv[VALUE]);
if(LMS_SetClockFreq(device,LMS_CLOCK_CGEN,cgen*1e6)){//setting for both channels
//lime::error("Could not set SXT");
cout<<"Could not set CGEN"<<endl;
ERROR_STAT = 1;
else if(type == "SXT" ){
double sxt=atof(argv[VALUE]);
if(LMS_SetClockFreq(device,LMS_CLOCK_SXT,sxt*1e6)){//setting for both channels
cout<<"Could not set SXT"<<endl;
ERROR_STAT = 1;
else if(type == "SXR" ){
double sxr=atof(argv[VALUE]);
if(LMS_SetClockFreq(device,LMS_CLOCK_SXR,sxr*1e6)){//setting for both channels
//lime::error("Could not set SXR");
cout<<"Could not set SXR"<<endl;
ERROR_STAT = 1;
int main(int argc,char** argv){
if(argc!=4){
cout<<"Error in arguments"<<endl;
return ERROR_ARG;//Error in arguments
int n;
int channel=atoi(argv[CHAN]);
lms_info_str_t list[8];
//INITIALIZE THE BOARD FOR COMMUNCATION
//get device list
if((n = LMS_GetDeviceList(list)) < 0){
cout<<"Could not get devices";
return NO_DEV;
//open the device
if(LMS_Open(&device,list[0],NULL)){
cout<<"Could not open device";
return NOT_OPEN;
LMS_SetClockFreq(device,LMS_CLOCK_REF,RFD_EXT_CLK);
if(type == "BW_TX" || type == "BW_RX" ){
if(type == "BW_TX"){
double bw_tx = atof(argv[VALUE]);
if(channel == 2){
if(LMS_SetLPFBW(device,LMS_CH_TX,0,bw_tx*1e6)){
cout<<"Could not set TX LPFBW for channel "<<char('A'+0)<<endl;
ERROR_STAT = 1;
return ERROR_STAT;
if(LMS_SetLPFBW(device,LMS_CH_TX,1,bw_tx*1e6)){
cout<<"Could not set TX LPFBW for channel "<<char('A'+1)<<endl;
ERROR_STAT = 1;
return ERROR_STAT;
else{
if(LMS_SetLPFBW(device,LMS_CH_TX,channel,bw_tx*1e6)){
cout<<"Could not set TX LPFBW for channel "<<char('A'+channel)<<endl;
ERROR_STAT = 1;
return ERROR_STAT;
else if(type == "BW_RX"){
double bw_rx = atof(argv[VALUE]);
if(channel == 2){
if(LMS_SetLPFBW(device,LMS_CH_RX,0,bw_rx*1e6)){
cout<<"Could not set RX LPFBW for channel "<<char('A'+0)<<endl;
ERROR_STAT = 1;
return ERROR_STAT;
if(LMS_SetLPFBW(device,LMS_CH_RX,1,bw_rx*1e6)){
cout<<"Could not set RX LPFBW for channel "<<char('A'+1)<<endl;
ERROR_STAT = 1;
return ERROR_STAT;
else{
if(LMS_SetLPFBW(device,LMS_CH_RX,channel,bw_rx*1e6)){
cout<<"Could not set RX LPFBW for channel "<<char('A'+channel)<<endl;
ERROR_STAT = 1;
return ERROR_STAT;
else{
setValue(argv);
return ERROR_STAT;
if(channel == 2){
//Set for channel A
ERROR_STAT = 1;
return ERROR_STAT;
//Set for channel B
ERROR_STAT = 1;
return ERROR_STAT;
else{
ERROR_STAT = 1;
return ERROR_STAT;
else{
setValue(argv);
return ERROR_STAT;
I am passing arguments to my script as sudo ./script BW_RX 20 0 for configuring channel A .
The arguments I am passing are BW_RX(RX Filter Bandwidth), Value(in MHz) and Channel(0 -->A, 1 --> B, 2 -->AB)
I realized the function does not give any error but affects the spectrum as CGEN is getting tuned by the MCU code indirectly every time I change the filter bandwidth.
Our system (FPGA for collecting I,Q samples ) is very sensitive to timing constraints as we see noisy sine waves on output if CGEN is not in phase with our reference clock.
