HI.
I use C++ to control the LimeSDR. Now I am trying to set a FIR for my LimeSDR
LMS_SetLPFBW(device, LMS_CH_TX, 0, 10e6);
LMS_SetLPFBW(device, LMS_CH_RX, 0, 1.5e6);
LMS_SetLPF(device, LMS_CH_TX, 0, true);
LMS_SetLPF(device, LMS_CH_RX, 0, true);
LMS_SetGFIR(device, LMS_CH_TX, 0, LMS_GFIR3, true);
LMS_SetGFIR(device, LMS_CH_RX, 0, LMS_GFIR3, true);
LMS_SetGFIRLPF(device, LMS_CH_TX, 0, true, 10e6);
LMS_SetGFIRLPF(device, LMS_CH_RX, 0, true, 1.5e6);
LMS_Calibrate(device, LMS_CH_TX, 0, 2.5e6, 0);
LMS_Calibrate(device, LMS_CH_RX, 0, 2.5e6, 0);
I am not sure this is right or not.
And GFIRLPF always show that GFIR LPF connect be set to the requested bandwidth.
What I want to do is using FIR to decrease the noise from the Antenna. The Sensor I use is a bit sensitivity, The result is good with cable, but when I add antenna into the system, the I cannot get the result. So, I guess it’s the noise problems.
Also, I cannot find the LimeSDR C++ API document, I have no idea the value that can set for LPF.
Anyone can help me? Thank you very much.
Also, Where is thee DC corrector on C++ library?
