As I understand LPFBW set an analog filter LPF, which should be decorelated from the sample rate.
If I call this function, it seems to change the samplerate.
See result and the extract code.
SR=2000000.000000 Decimation=16
SR 2000000.000000 DAC 32000000.000000
Valid BP=1400000.000000-130000000.000000 by 1.000000 step
RX LPF configured
Bandwidth=2000000.000000
SR 798125.011580 DAC 25540000.370571
if (LMS_SetSampleRate(device, m_sr, OVERSAMPLE) != 0)
fprintf(stderr,"SR Not Set with decimation %d\n",OVERSAMPLE);
else
fprintf(stderr, "SR=%f Decimation=%d\n",m_sr, OVERSAMPLE);
float_type HostSR, DacSR;
LMS_GetSampleRate(device, LMS_CH_RX, 0, &HostSR, &DacSR);
fprintf(stderr,"SR %f DAC %f\n", HostSR, DacSR);
lms_range_t RangeBP;
LMS_GetLPFBWRange(device,LMS_CH_RX,&RangeBP);
fprintf(stderr, "Valid BP=%f-%f by %f step\n", RangeBP.min, RangeBP.max, RangeBP.step);
m_Bandwidth=m_sr;
m_Bandwidth = (m_sr < RangeBP.min) ? RangeBP.min : m_Bandwidth;
m_Bandwidth = (m_sr > RangeBP.max) ? RangeBP.max : m_Bandwidth;
LMS_SetLPFBW(device, LMS_CH_RX, 0, m_Bandwidth);
float_type BandWidth;
LMS_GetLPFBW(device,LMS_CH_RX,0,&BandWidth);
fprintf(stderr,"Bandwidth=%f\n",BandWidth);
