I’ve been able to run osmo-nitb with LimeSDR-USB on a clean Xubuntu 17.04 system. I wrote a wiki, because I had hard times actually running it - issues with Snaps, PPAs, package versions and so on. I wouldn’t want others to suffer the same
Hope it helps. Please let me know if there is something that is not correct or can be improved.
Looks good, although AFAIK Snaps should not interfere as they are containerised and each package Lime Suite together with an SDR app. E.g. you could have many copies of Lime Suite, all different versions, sitting side-by-side — albeit in their protected R/O filesystem along with the app that uses it.
However, installing Lime Suite from Debian packages and source is a very bad idea.
Thanks this is guide, but doesn’t seem to work on 17.10. All is well, but UHD does not seem to know about the LimeSDR. Since 17.04 is no long available, I cannot try that but 17.10 isn’t really that much different. I’m wondering if the SDR firmware upgrade has caused an issue?
