I checked all wiki instructions and previous posts in Discourse without joy.
When inserting my LimeSDR Mini, I see it in lsusb but not LimeUtil
$ lsusb
Bus 002 Device 006: ID 0403:601f Future Technology Devices International, Ltd
$ LimeUtil --update
No devices found
Any advice?
i think you have to install the udev-rules
cd LimeSuite/udev-rules
chmod +x install.sh
Thanks for the input. I did that, and did it again without luck
~/LimeSuite/udev-rules$ sudo ./install.sh
[sudo] password for bjorn:
~/LimeSuite/udev-rules$ LimeUtil --update
No devices found
I am not sure, but it is important to install all software in the right order. Maybe that’s your problem.
it’s best if you uninstall everything first and try it with a fresh install.
I had written a bash script for myself, maybe it will help you:
#!/bin/sh
if [ "$(id -u)" == "0" ]; then
echo "This script must be run as normal User" 1>&2
exit 1
fi
user="$USER"
sudo apt update -y
sudo apt upgrade -y
sudo apt install g++ -y
sudo apt install libcurl4-openssl-dev -y
sudo apt install libssl-dev -y
sudo apt install libsqlite3-dev -y
sudo apt install libboost-program-options-dev -y
sudo apt install zlib1g-dev -y
sudo apt install plink -y
sudo apt install libpython-dev -y
sudo apt install python-numpy -y
sudo apt install swig -y
sudo apt install libgps-dev -y
sudo apt install gpsd -y
sudo apt install gpsd-clients -y
sudo apt install libjsoncpp-dev -y
sudo apt install libusb-1.0-0-dev -y
sudo apt install git -y
sudo apt install cmake -y
sudo apt install build-essential -y
sudo apt install libmbedtls-dev -y
sudo apt install libconfig++-dev -y
sudo apt install libsctp-dev -y
sudo apt install libfftw3-dev -y
sudo apt install libi2c-dev -y
sudo apt install libboost-all-dev -y
if [ -d /home/$user/SoapySDR ]; then
echo " - SoapySDR already exists. Skipping it."
else
##sudo apt-get install soapysdr-tools -y
git clone https://github.com/pothosware/SoapySDR.git
cd SoapySDR || exit
git pull origin master
mkdir build
cd build || exit
cmake ..
make -j4
sudo make install
sudo ldconfig #needed on debian systems
cd /home/$user/ || exit
fi
if [ -d /home/$user/LimeSuite ]; then
echo " - LimeSuite already exists. Skipping it."
else
##sudo apt install libsoapysdr-dev -y
sudo apt install libwxgtk3.0-dev -y
sudo apt install freeglut3-dev -y
#sudo apt install limesuite -y
#sudo apt install liblimesuite-dev -y
#sudo apt install limesuite-udev -y
#sudo apt install soapysdr-tools -y
#sudo apt install soapysdr-module-lms7 -y
git clone https://github.com/myriadrf/LimeSuite.git
cd LimeSuite || exit
git checkout stable
mkdir builddir && cd builddir || exit
cmake ../
make -j4
sudo make install
sudo ldconfig
cd /home/$user/LimeSuite/udev-rules || exit
chmod +x install.sh
sudo ./install.sh
fi
Great script! Got it working. Thanks a lot. I had to start with a fresh Ubuntu 18.04 though. Will try to uninstall everything on the first one.
Should work fine on Ubuntu 18.04 with an install via packages from the PPA. That’s what I’m currently using…
