The satellite is transmitting QPSK modulated data stream with bitrate of 186.6Mbps at 7.825GHz.
We are evaluating if LMS8001 + LMS7002M could be used for the signal reception.
One of possible problems we have identified is the fact that maximum sampling rate of LMS7002M with internal ADC in SISO mode is 96MHz which may not provide sufficient oversampling factor for successful demodulation. The only possible solution we have identified is to use external LA9310 baseband processor with sample rate of 153MHz. Are there any other options? Is faster sample rate possible with the internal ADC if sample resolution could be reduced from 12-bit?
