dtri03@dtri03:~/Documents/openairinterface5g/cmake_targets/ran_build/build$ sudo ./nr-softmodem -O ~/Documents/openairinterface5g/targets/PROJECTS/GENERIC-NR-5GC/CONF/lmssdr_24PRB.conf --rf-config-file ~/Documents/openairinterface5g/radio/LMSSDR/Limesdr_mini_v2_1.cfg
CMDLINE: “./nr-softmodem” “-O” “/home/dtri03/Documents/openairinterface5g/targets/PROJECTS/GENERIC-NR-5GC/CONF/lmssdr_24PRB.conf” “–rf-config-file” “/home/dtri03/Documents/openairinterface5g/radio/LMSSDR/Limesdr_mini_v2_1.cfg”
[CONFIG] function config_libconfig_init returned 0
[UTIL] running in SA mode (no --phy-test, --do-ra, --nsa option present)
[OPT] OPT disabled
[HW] Version: Branch: limesuiteng-integration Abrev. Hash: d948c2962f Date: Mon Jan 26 18:46:49 2026 +0200
[GNB_APP] Initialized RAN Context: RC.nb_nr_inst = 1, RC.nb_nr_macrlc_inst = 1, RC.nb_nr_L1_inst = 1, RC.nb_RU = 1, RC.nb_nr_CC[0] = 1
[NR_PHY] Initializing gNB RAN context: RC.nb_nr_L1_inst = 1
[NR_PHY] Registered with MAC interface module (0x55a5a85e5b90)
[NR_PHY] Initializing NR L1: RC.nb_nr_L1_inst = 1
[NR_PHY] L1_RX_THREAD_CORE -1 (15)
[NR_PHY] TX_AMP = 519 (-36 dBFS)
[PHY] No prs_config configuration found..!!
[GNB_APP] pdsch_AntennaPorts N1 1 N2 1 XP 1 pusch_AntennaPorts 1
[GNB_APP] minTXRXTIME 6
[GNB_APP] CSI-RS 0, SRS 0, report type 0 (ssb_rsrp), 256 QAM may be on, delta_MCS off, maxMIMO_Layers -1, HARQ feedback enabled, num DLHARQ:16, num ULHARQ:16
[GNB_APP] No RedCap configuration found
[GNB_APP] No PTRS configuration found
[GNB_APP] sr_ProhibitTimer 0, sr_TransMax 64, sr_ProhibitTimer_v1700 0, t300 400, t301 400, t310 2000, n310 10, t311 3000, n311 1, t319 400
[NR_MAC] Candidates per PDCCH aggregation level on UESS: L1: 0, L2: 2, L4: 0, L8: 0, L16: 0
[RRC] Read in ServingCellConfigCommon (PhysCellId 0, ABSFREQSSB 640320, DLBand 78, ABSFREQPOINTA 640032, DLBW 24,RACH_TargetReceivedPower -96
[RRC] absoluteFrequencySSB 640320 corresponds to 3604800000 Hz
[NR_MAC] TDD period index = 6, based on the sum of dl_UL_TransmissionPeriodicity from Pattern1 (5.000000 ms) and Pattern2 (0.000000 ms): Total = 5.000000 ms
[UTIL] threadCreate() for MAC_STATS: creating thread with affinity ffffffff, priority 2
[NR_MAC] PUSCH Target 150, PUCCH Target 200, PUCCH Failure 10, PUSCH Failure 10
[NR_PHY] Copying 0 blacklisted PRB to L1 context
[NR_MAC] Set TX antenna number to 1, Set RX antenna number to 1 (num ssb 1: 80000000,0)
[NR_MAC] Set TDD configuration period to: 8 DL slots, 3 UL slots, 10 slots per period (NR_TDD_UL_DL_Pattern is 7 DL slots, 2 UL slots, 6 DL symbols, 4 UL symbols)
[NR_MAC] Configured 1 TDD patterns (total slots: pattern1 = 10, pattern2 = 0)
[NR_PHY] Set TDD Period Configuration: 2 periods per frame, 20 slots to be configured (8 DL, 3 UL)
[NR_PHY] TDD period configuration: slot 0 is DOWNLINK
[NR_PHY] TDD period configuration: slot 1 is DOWNLINK
[NR_PHY] TDD period configuration: slot 2 is DOWNLINK
[NR_PHY] TDD period configuration: slot 3 is DOWNLINK
[NR_PHY] TDD period configuration: slot 4 is DOWNLINK
[NR_PHY] TDD period configuration: slot 5 is DOWNLINK
[NR_PHY] TDD period configuration: slot 6 is DOWNLINK
[NR_PHY] TDD period configuration: slot 7 is FLEXIBLE: DDDDDDFFFFUUUU
[NR_PHY] TDD period configuration: slot 8 is UPLINK
[NR_PHY] TDD period configuration: slot 9 is UPLINK
[NR_MAC] Command line parameters for OAI UE: -C 3604800000 -r 24 --numerology 1 --band 78 --ssb 24
[NR_PHY] dlfreq:3604800 ulfreq:3604800 deltaduplex:0 khz, uldl_min_offset:0 khz
DL frequency 3604800000: band 78, UL frequency 3604800000
[PHY] DL frequency 3604800000 Hz, UL frequency 3604800000 Hz: band 78, uldl offset 0 Hz
[PHY] Initializing frame parms for mu 1, N_RB 24, Ncp 0
[PHY] Init: N_RB_DL 24, first_carrier_offset 368, nb_prefix_samples 36,nb_prefix_samples0 44, ofdm_symbol_size 512
[NR_MAC] TDA index 0: start 0 length 13 k2 6
[NR_MAC] TDA index 1: start 10 length 3 k2 6
[NR_RRC] SIB1 freq: offsetToPointA 4
[GNB_APP] F1AP: gNB idx 0 gNB_DU_id 3584, gNB_DU_name gNB-OAI, TAC 1 MCC/MNC/length 1/1/2 cellID 12345678
[GNB_APP] ngran_DU: Configuring Cell 0 for TDD
[GNB_APP] SDAP layer is disabled
[GNB_APP] Data Radio Bearer count 1
[GNB_APP] Parsed IPv4 address for NG AMF: 192.168.1.46
[UTIL] threadCreate() for TASK_SCTP: creating thread with affinity ffffffff, priority 50
[X2AP] X2AP is disabled.
[UTIL] threadCreate() for TASK_NGAP: creating thread with affinity ffffffff, priority 50
[NGAP] Starting NGAP layer
[UTIL] threadCreate() for TASK_RRC_GNB: creating thread with affinity ffffffff, priority 50
[NGAP] Registered new gNB[0] and macro gNB id 3584
[NGAP] [gNB 0] check the amf registration state
[GTPU] Configuring GTPu
[GTPU] SA mode
[GTPU] Configuring GTPu address : 192.168.1.46, port : 2152
[GTPU] Initializing UDP for local address 192.168.1.46 with port 2152
[GTPU] Created gtpu instance id: 90
[UTIL] threadCreate() for GTPrx_90: creating thread with affinity ffffffff, priority 50
[NR_RRC] Entering main loop of NR_RRC message task
[UTIL] threadCreate() for TASK_GNB_APP: creating thread with affinity ffffffff, priority 50
[NR_RRC] Accepting new CU-UP ID 3584 name gNB-OAI (assoc_id -1)
[UTIL] threadCreate() for TASK_GTPV1_U: creating thread with affinity ffffffff, priority 50
[NR_RRC] Received F1 Setup Request from gNB_DU 3584 (gNB-OAI) on assoc_id -1
[NR_RRC] Accepting DU 3584 (gNB-OAI), sending F1 Setup Response
[NR_RRC] DU uses RRC version 17.3.0
[MAC] received F1 Setup Response from CU (null)
[MAC] CU uses RRC version 17.3.0
[MAC] Clearing the DU’s UE states before, if any.
[NR_RRC] cell PLMN 001.01 Cell ID 12345678 is in service
[MAC] received gNB-DU configuration update acknowledge
[UTIL] threadCreate() for time source realtime: creating thread with affinity ffffffff, priority 2
[UTIL] time manager configuration: [time source: reatime] [mode: standalone] [server IP: 127.0.0.1} [server port: 7374] (server IP/port not used)
[PHY] RU clock source set as internal
[PHY] number of L1 instances 1, number of RU 1, number of CPU cores 8
[PHY] Initialized RU proc 0 (,synch_to_ext_device),
[PHY] RU thread-pool core string -1,-1 (size 2)
[UTIL] threadCreate() for Tpool0_-1: creating thread with affinity ffffffff, priority 97
[UTIL] threadCreate() for Tpool1_-1: creating thread with affinity ffffffff, priority 97
[UTIL] threadCreate() for ru_thread: creating thread with affinity ffffffff, priority 97
[PHY] Starting RU 0 (,synch_to_ext_device) on cpu 5
[PHY] fp->scs=30000
[PHY] fp->ofdm_symbol_size=512
[PHY] fp->nb_prefix_samples0=44
[PHY] fp->nb_prefix_samples=36
[PHY] fp->slots_per_subframe=2
[PHY] fp->samples_per_subframe_wCP=14336
[PHY] fp->samples_per_frame_wCP=143360
[PHY] fp->samples_per_subframe=15360
[PHY] fp->samples_per_frame=153600
[PHY] fp->dl_CarrierFreq=3604800000
[PHY] fp->ul_CarrierFreq=3604800000
[PHY] fp->Nid_cell=0
[PHY] fp->first_carrier_offset=368
[PHY] fp->ssb_start_subcarrier=0
[PHY] fp->Ncp=0
[PHY] fp->N_RB_DL=24
[PHY] fp->numerology_index=1
[PHY] fp->nr_band=78
[PHY] fp->ofdm_offset_divisor=8
[PHY] fp->threequarter_fs=0
[PHY] fp->sl_CarrierFreq=0
[PHY] fp->N_RB_SL=0
[NR_PHY] nb_tx_streams 1, nb_rx_streams 1, num_Beams_period 1
[PHY] Setting RF config for N_RB 24, NB_RX 1, NB_TX 1
[PHY] tune_offset 0 Hz, sample_rate 15360000 Hz
[PHY] Channel 0: setting tx_gain offset 0, tx_freq 3604800000 Hz
[PHY] Channel 0: setting rx_gain offset 114, rx_freq 3604800000 Hz
[HW] rf-config-file: /home/dtri03/Documents/openairinterface5g/radio/LMSSDR/Limesdr_mini_v2_1.cfg
[HW] Available devices:
[HW] “dspR_test, media=USB3.0, addr=0403:601f, serial=00000000000013”
[HW] Connected: dspR_test, media=USB3.0, addr=0403:601f, serial=00000000000013
[HW] FPGA: StopStreaming
[HW] lms7002m_set_tx_lpf: bandwidth(20000000): LAD=140, H=0
[HW] INT 57, FRAC 385875, DIV_OUTCH_CGEN 18
[HW] CGEN_VCO 14720000 Hz, RefClk 40000000 Hz
[HW] Calibrating CG_IAMP_TBB:
[HW] CG_IAMP_TBB(1) RSSI:0x00002872 approx. -16.24 dBFS
[HW] CG_IAMP_TBB(2) RSSI:0x00002AF6 approx. -15.72 dBFS
[HW] CG_IAMP_TBB(3) RSSI:0x000036D5 approx. -13.60 dBFS
[HW] CG_IAMP_TBB(4) RSSI:0x00004319 approx. -11.85 dBFS
[HW] CG_IAMP_TBB(5) RSSI:0x00005283 approx. -10.05 dBFS
[HW] CG_IAMP_TBB(6) RSSI:0x00005DC8 approx. -8.94 dBFS
[HW] CG_IAMP_TBB(7) RSSI:0x00006E5F approx. -7.52 dBFS
[HW] CG_IAMP_TBB(8) RSSI:0x00007AAA approx. -6.61 dBFS
[HW] CG_IAMP_TBB(9) RSSI:0x00008BA5 approx. -5.48 dBFS
[HW] CG_IAMP_TBB(10) RSSI:0x0000975D approx. -4.78 dBFS
[HW] CG_IAMP_TBB(11) RSSI:0x0000A7C8 approx. -3.88 dBFS
[HW] CG_IAMP_TBB(12) RSSI:0x0000B502 approx. -3.23 dBFS
[HW] lms7002m_set_rx_lpf: bandwidth(20000000): TIA_C=242, TIA_RCOMP=11, TIA_CCOMP=2, RX_L_C=59, RX_H_C=255
[HW] Sampling rate set(20.000 MHz): CGEN:160.000 MHz, Decim: 2^1, Interp: 2^1
[HW] INT 63, FRAC 0, DIV_OUTCH_CGEN 7
[HW] CGEN_VCO 0 Hz, RefClk 40000000 Hz
[HW] FPGA SetPllFrequency: PLL[0] input:40.000 MHz clockCount:4
[HW] CLK[3] Fout:40.000 MHz bypass:0 phase:139.06 findPhase: 1
[HW] FPGA PLL[0] M=32, N=1, Fvco=1280.000 MHz (Requested 1280.000 MHz)
[HW] CLK[1] Fout:40.000 MHz bypass:0 phase:100.45 findPhase: 1
[HW] dev0 chip0 loaded with: /home/dtri03/Documents/openairinterface5g/radio/LMSSDR/test5Gnew.ini
[HW] Rx channel0: dev0 chip0 ch0 , LO: 3604.800 MHz SR: 15.360 MHz BW: 10.000 MHz | path: 0(‘NONE’)
[HW] Tx channel0: dev0 chip0 ch0 , LO: 3604.800 MHz SR: 15.360 MHz BW: 10.000 MHz | path: 0(‘None’)
[HW] dev0 configure.
[HW] Set Rx LO frequency (3604800000 Hz)
[HW] SX VCO:7209600000 Hz, RefClk:40000000 Hz, INT:86, FRAC:125829, DIV_LOCH:0, EN_DIV2_DIVPROG:1
[HW] Tuning Rx VCOH (ICT_VCO:192):
[HW] TuneVCO(SXR) - searching interval [0:128]
[HW] binary search:
[HW] csw=64 cmphl=0
[HW] csw=96 cmphl=0
[HW] csw=112 cmphl=0
[HW] csw=120 cmphl=0
[HW] csw=124 cmphl=0
[HW] csw=126 cmphl=0
[HW] csw=127 cmphl=0
[HW] adjust with linear search:
[HW] CSW interval failed to lock
[HW] TuneVCO(SXR) - searching interval [128:256]
[HW] binary search:
[HW] csw=192 cmphl=3
[HW] csw=160 cmphl=2
[HW] csw=176 cmphl=3
[HW] csw=168 cmphl=2
[HW] csw=172 cmphl=3
[HW] csw=170 cmphl=2
[HW] csw=171 cmphl=2
[HW] csw=159 cmphl=2
[HW] csw=158 cmphl=2
[HW] csw=157 cmphl=2
[HW] csw=156 cmphl=2
[HW] csw=155 cmphl=2
[HW] csw=154 cmphl=2
[HW] csw=153 cmphl=2
[HW] csw=152 cmphl=2
[HW] csw=151 cmphl=2
[HW] csw=150 cmphl=2
[HW] csw=149 cmphl=0
[HW] CSW: lowest=150, highest=171, will use=160
[HW] choosing wider CSW locking range: low=150, high=171
[HW] TuneVCO(SXR) - confirmed lock with final csw=160, cmphl=2
[HW] VCOH : csw=160 tune ok
[HW] Selected: VCOH, CSW_VCO: 160
[HW] Set Tx LO frequency (3604800000 Hz)
[HW] Tuning Tx VCOH (ICT_VCO:192):
[HW] TuneVCO(SXT) - searching interval [0:128]
[HW] binary search:
[HW] csw=64 cmphl=0
[HW] csw=96 cmphl=0
[HW] TuneVCO(SXT) - searching interval [128:256]
[HW] binary search:
[HW] csw=172 cmphl=2
[HW] csw=174 cmphl=3
[HW] csw=173 cmphl=2
[HW] csw=152 cmphl=0
[HW] CSW: lowest=153, highest=173, will use=163
[HW] choosing wider CSW locking range: low=153, high=173
[HW] TuneVCO(SXT) - confirmed lock with final csw=163, cmphl=2
[HW] VCOH : csw=163 tune ok
[HW] Selected: VCOH, CSW_VCO: 163
[HW] lms7002m_set_rx_lpf: modifying G_PGA_RBB 28 → 12
[HW] lms7002m_set_rx_lpf: bandwidth(10000000): TIA_C=494, TIA_RCOMP=6, TIA_CCOMP=4, RX_L_C=221, RX_H_C=255
[HW] lms7002m_set_tx_lpf: bandwidth(10000000): LAD=46, H=0
[HW] Custom .ini configuration file is loaded, SetTxLPF will not calibrate CG_IAMP_TBB
[HW] lms7002m_set_rx_lpf: RxLPF bypassed
[HW] lms7002m_set_tx_lpf: TxLPF bypassed.
[HW] Sampling rate set(15.360 MHz): CGEN:491.520 MHz, Decim: 2^3, Interp: 2^3
[HW] INT 48, FRAC 159383, DIV_OUTCH_CGEN 1
[HW] CGEN_VCO 6080000 Hz, RefClk 40000000 Hz
[HW] FPGA SetPllFrequency: PLL[0] input:15.360 MHz clockCount:4
[HW] CLK[3] Fout:15.360 MHz bypass:0 phase:108.506 findPhase: 1
[HW] FPGA PLL[0] M=83, N=1, Fvco=1274.880 MHz (Requested 1274.880 MHz)
[HW] CLK[1] Fout:15.360 MHz bypass:0 phase:93.7726 findPhase: 1
[HW] Port[0] Stream samples format: I12 , link: I12
[HW] [RAU] has loaded LMSSDR device.
[PHY] RU 0 Setting N_TA_offset to 200 samples (UL Freq 3600480, N_RB 24, mu 1)
[PHY] Signaling main thread that RU 0 is ready, sl_ahead 6
[PHY] L1 configured without analog beamforming
[PHY] Attaching RU 0 antenna 0 to gNB antenna 0
[UTIL] threadCreate() for Tpool2_-1: creating thread with affinity ffffffff, priority 97
[UTIL] threadCreate() for Tpool3_-1: creating thread with affinity ffffffff, priority 97
[UTIL] threadCreate() for Tpool4_-1: creating thread with affinity ffffffff, priority 97
[UTIL] threadCreate() for Tpool5_-1: creating thread with affinity ffffffff, priority 97
[UTIL] threadCreate() for Tpool6_-1: creating thread with affinity ffffffff, priority 97
[UTIL] threadCreate() for Tpool7_-1: creating thread with affinity ffffffff, priority 97
[UTIL] threadCreate() for L1_rx_thread: creating thread with affinity ffffffff, priority 97
[UTIL] threadCreate() for L1_tx_thread: creating thread with affinity ffffffff, priority 97
[UTIL] threadCreate() for L1_stats: creating thread with affinity ffffffff, priority 1
TYPE TO TERMINATE
[PHY] got sync (L1_stats_thread)
[PHY] got sync (ru_thread)
[HW] FPGA: StartStreaming
[PHY] RU 0 rf device ready
[PHY] RU 0 RF started cpu_meas_enabled 0
[HW] Tx transmit loop start.
[HW] Rx receive loop start.
[PHY] Command line parameters for OAI UE: -C 3604800000 -r 24 --numerology 1 --ssb 24
[HW] USB ep:83 Rx0: 46.260 MB/s | TS:15357120 pkt:11293 o:0(+0) l:0(+0) dma:11293/11294(+1) swFIFO:0
[HW] USB ep:03 Tx0: 34.250 MB/s | TS:15398400 pkt:8397 u:0(+0) l:0(+0) dma:1794/1799(+5) tsAdvance:+1932/+2274/+2541us, f:0
[NR_MAC] Frame.Slot 128.0
[HW] USB ep:83 Rx0: 46.260 MB/s | TS:30716960 pkt:22587 o:0(+0) l:0(+0) dma:22587/22588(+1) swFIFO:0
[HW] USB ep:03 Tx0: 34.368 MB/s | TS:30758400 pkt:16797 u:0(+0) l:0(+0) dma:3594/3599(+5) tsAdvance:+1984/+2274/+2541us, f:0
[NR_MAC] Frame.Slot 256.0
[HW] USB ep:83 Rx0: 46.260 MB/s | TS:46075440 pkt:33880 o:0(+0) l:0(+0) dma:33880/33882(+2) swFIFO:0
[HW] USB ep:03 Tx0: 34.388 MB/s | TS:46118400 pkt:25197 u:0(+0) l:0(+0) dma:5395/5399(+4) tsAdvance:+2015/+2273/+2541us, f:0
[NR_MAC] Frame.Slot 384.0
[HW] USB ep:83 Rx0: 46.264 MB/s | TS:61438000 pkt:45176 o:0(+0) l:0(+0) dma:45176/45177(+1) swFIFO:0
[HW] USB ep:03 Tx0: 34.388 MB/s | TS:61486080 pkt:33602 u:0(+0) l:0(+0) dma:7196/7200(+4) tsAdvance:+1953/+2273/+2541us, f:0
[HW] USB ep:83 Rx0: 46.260 MB/s | TS:76797840 pkt:56470 o:0(+0) l:0(+0) dma:56470/56471(+1) swFIFO:0
[HW] USB ep:03 Tx0: 34.368 MB/s | TS:76846080 pkt:42002 u:0(+0) l:0(+0) dma:8996/9000(+4) tsAdvance:+1979/+2273/+2541us, f:0
[NR_MAC] Frame.Slot 512.0HW] CLK[3] Fout:15.360 MHz bypass:0 phase:108.506 findPhase: 1
[HW] chip0 ch0 Rx gain set LNA:15, PGA:31
[HW] chip0 ch0 Tx gain set MAIN:30, LIN:30
[HW] FPGA: StopWaveformPlayback
[HW] FPGA: ResetPacketCounters
[HW] FPGA: ResetTimestamp
[HW] USB ep:83 Rx0 Setup: usePoll:1 rxSamplesInPkt:1360 rxPacketsInBatch:1, DMA_ReadSize:4096, link:I12, batchSizeInTime:88.5417us FS:15360000.000000, FIFO=2823*1360
[HW] RxSetup wait for Rx worker thread.
[HW] Rx worker thread ready.
[HW] Tx0 Setup: samplesInTxPkt:1360 maxTxPktInBatch:5, batchSizeInTime:442.708us
[HW] TxSetup wait for Tx worker.
[HW] Tx worker thread ready.
TYPE TO TERMINATE
