Hello I noticed many errors while using SoapySDR and calibrating the LimeSDR. The error was always “Tx Calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)”
I have since run LimeQuickTest which also indicated an rf loopback problem: RF Loopback Test FAILED
->Start time: Sat Feb 23 12:52:31 2019
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009060A02431111
Serial Number: 0009060A02431111
->FX3 GPIF clock test
Test results: 28905; 32661; 36417 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112908 (min); 5113048 (max) - PASSED
->Clock Network Test PASSED
->Read data: 11 02 15 11 02 15 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
CGEN: Freq=80 MHz, VCO=2.4 GHz, INT=77, FRAC=131072, DIV_OUTCH_CGEN=14
CGEN: Freq=491.52 MHz, VCO=1.96608 GHz, INT=63, FRAC=0, DIV_OUTCH_CGEN=1
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-13.7 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.4 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-14.4 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-21.3 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-16.9 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-13.8 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.47 seconds
How do we proceed? I am quite devastated as I have never used the device because I was so scared of breaking it. Now I finally have a case for it and then this happens. I really hope we can resolve this issue.
