I just received my LimeSDR and we are wanting to begin testing our antenna to characterize the environment. We are using a 2.4-2.5GHz antenna connected to the RX1_H port. The LimeSDR is connected to a PC running GNU radio companion on Debian.
Since I am fairly new to all of this, I have had a hard time selecting the correct parameters on the source block. Therefore, I have multiple questions like is there a recommended sampling rate, value for gain, bandwidth and/or other parameters that could skew my results. I do not know if it is just standardized values or if we need specify values for the LimeSDR.
One other questions I have is: how do I specify on the source block which receive port I am using and is it possible to switch ports?
Thank you,
Ricardo
