I made a new set of measurements with a R&S analyzer:
https://open-cells.com/index.php/2018/05/04/limesdr-new-set-of-tests/
My results is that the LimeSDR driver is still not stable and usable, on Tx, and probably also on Rx
Also, the Lime .ini file is mandatory: even calling all available setting and calibration functions on the API is not enough to run correctly a LimeSDR.
There is no explanations on how to build such .ini file.
I’ve put more details on the results:
details on the calls to the limeSDR API to try to setup a correct configuration:
I don’t think LimeSDR is working fine: with a good ini file, in specific band and frequency, one may reach a RF communication, BUT too many problems are still existing (see this blog other reports).
