Open-source CNC aluminum case for LimeSDR USB: RF-shielded, thermal pads, full SMA breakout
Hi all,
I’m sharing an open-source CNC enclosure project for LimeSDR USB.
GitHub:
What this case focuses on:
  • Mechanical protection
  • Passive thermal dissipation with thermal interface pads
  • RF/control area separation and RF firewall concept
  • Full SMA breakout support + laser marking file
Included files:
  • top.step / bottom.step
  • top.f3d / bottom.f3d
  • Laser_Marking.dwg
  • Pilot build photos and assembly notes
Manufacturing:
I tested a pilot build with JLCCNC/JLC-style workflow using STEP + optional laser marking DWG.
Assembly notes:
  • Threads are not pre-modeled; user taps threads during assembly
  • M4x30 for case halves
  • M3x4 flat-head for PCB mounting
  • Fan area supports 4010 (40x40x10), but passive cooling was enough in my RX use case (~34C)
Cable note:
For RF-side SMA-IPEX links I recommend RG113 75 mm. 100 mm can work but makes assembly harder.
Feedback on geometry/DFM is welcome.
Thanks for sharing, looks great!
