I was suggested by the reseller ( Poolage Store) that I have to post here to file a complaint.
It is strange but I comply with. I wasn’t able to find any customer CSS like for instance ZenDesk so I write here.
The problem description is here : https://drive.google.com/drive/folders/10f6NrYIr8SOcL35H-WEy_cnHiV-dPxwS?usp=sharing
The quick test was performed using LimeQuickTest_20.10.0 with no antenna connected.
BTW You can use technical language , I am engineer graduated with Masters degree in computer science from a technical university.
Best
->Start time: Fri Dec 18 10:44:18 2020
->Device: LimeSDR Mini, media=USB 3, module=FT601, serial=1D589836107205, index=0, HW=3, GW=1.30
Serial Number: 1D589836107205
Chip temperature: 27 C
->REF clock test
Test results: 47927; 61124; 8785 - PASSED
Results : 6711006 (min); 6711160 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 0A 17 13 0A 17 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
Hi, Zack,
The problem is that the seller has been told to make me contact with the producer.
If it is the Myriad’s official statement I will go back to the seller.
Best
