We are trying to setup high power PA and LNA on LimeSDR for the LTE project.
We want to know how to make use of the on-chip AGC. Is it controlled by the RSSI automatically, or do we need to configure in LimeSuiteGUI?
I know there is an option in srsLTE to choose rx_gain automatically, but we are not sure whether it talks with LMS7002 well since there are too many intermediate layers like Soapy.
After reading the documents. I still have some doubts.
According to LimeSDR Made simple series 2. There are 3 stages of amplifiers in the receiving path. primary LNA, RxTIA and RxPGA. Which amplifier stage is the MCU_AGCStart() function actually tuning? And this MCU_AGC is based on the digital rssi instead of the analog rssi right?
I enabled the AGC checkbox in LimeSuiteGUI, and then I put a walkie-talkie nearby the LimeSDR, but when I move the walkie-talkie around, the amplitude of its signal on fftviewer is always changing. It is supposed to be maintained almost as constant right?
I was using LimeSuite 18.01 and AGC isn’t working properly.
Now I am using with LimeSuite 18.04 and 18.06, the AGC is working now.
I tested for LimeSDR-USB with walkie-talkie, now it really maintain constant power level regardless of distance. But LimeSDR-Mini seems not supported yet.
