Does AGC is enable by default?
anyone know how to make AGC disable?
Im trying to setup LimeSDR using PA+LNA and I need to make sure the AGC is not enable.
on the MCU AGC, the option only tick to enable it. but I believe the AGC is loop by default.
Hello again Ignas,
ok, I was think it was enable by default because I cannot turn it on at gqrx, but then I realize my LNA (BT200) is damage to use with LimeSDR-USB, so Im gonna buy again for replacement.
Does Myriad/LimeSDR has project of the PA+LNA? I know its not meet the crowd supply requirement for target reach, but is it possible to get it?
curios about LNA4ALL gain to use in 900/1800mhz compare with BT200.
