I’m hearing through sources that there is digital filtering in the LMS7002 that currently is optimized for higher bands, but may not be optimized for HF. The source mentioned:
“…I visited LimeSDR developers team and had a long discussion about their SDR products, especially LimeSDR. I found that low RF bands limit is not only RF front end limitation, it also defined by LMS7002 digital filtering, etc…”
Now before anyone replies about the confusion on the matching networks and this digital filtering let me make it clear that they are completely separate issues - that the matching networks have known performance curves that are more suitable for VHF to SHF, but are usable in HF but not optimal. That can be overcome by designing and building other input circuitry to supplant the current design if needed - and I would think that for those that want to use their LimeSDRs in the HF range someone is going to work that issue and come up with a mod for that. I’m certainly thinking hard on that.
But it’s the digital filtering in the LMS7002 that can’t easily be overcome right now. It’s, from what I’ve been advised, intrinsic to the design of the LimeSDR as it is now, but it would be great if we knew how to resolve that issue to provide the LMS7002 better performance in the HF range (2.0 - 30 MHz, but it would be great if it could be extended to 56 MHz).
Who can shed light on this subject? Since the LimeSDR is open source, how can we obtain better performance from the digital filtering for HF?
Advise at your soonest - thanks, Marty (KN0CK)
