From the “LMS7002M DataSheet” -
“RX analog filters are tunable from 0.7 MHz to 80 MHz.”
“The TX filtering chain pass band is tunable from 2 MHz to 80 MHz”
So 48kHz samplerates in your flowgraphs is not good.
Those error messages are coming from here at a guess, and the limits look to be slightly different than those defined in the LMS7002M datasheet:
lime::debug("MCU Ref. clock: %g MHz", refClk / 1e6);
//set bandwidth for MCU to read from register, value is integer stored in MHz
mcuControl->SetParameter(MCU_BD::MCU_BW, rx_lpf_freq_RF);
mcuControl->RunProcedure(5);
status = mcuControl->WaitForMCU(1000);
if(status != MCU_BD::MCU_NO_ERROR)
lime::error("Tune Rx Filter: MCU error %i (%s)", status, MCU_BD::MCUStatusMessage(status));
return -1;
//sync registers to cache
std::vector<uint16_t> regsToSync = {0x0112, 0x0117, 0x011A, 0x0116, 0x0118, 0x0114, 0x0019, 0x0115};
for(const auto addr : regsToSync)
this->SPI_read(addr, true);
return status;
int LMS7002M::TuneTxFilter(const float_type tx_lpf_freq_RF)
@file LMS7002M_filtersCalibration.cpp
@author Lime Microsystems (www.limemicro.com)
@brief Implementation of LMS7002M transceiver filters calibration algorithms
#include "LMS7002M.h"
#include "IConnection.h"
#include "Logger.h"
#include "LMS7002M_RegistersMap.h"
#include <cmath>
#include <iostream>
#include <assert.h>
#include "MCU_BD.h"
#include "mcu_programs.h"
#include "Logger.h"
#ifdef _MSC_VER
#include <ciso646>
#endif
using namespace lime;
//rx lpf range limits
static const float_type RxLPF_RF_LimitLow = 1.4e6;
static const float_type RxLPF_RF_LimitHigh = 130e6;
//tx lpf range limits
const float_type TxLPF_RF_LimitLow = 5e6;
const float_type TxLPF_RF_LimitLowMid = 40e6;
const float_type TxLPF_RF_LimitMidHigh = 50e6;
const float_type TxLPF_RF_LimitHigh = 130e6;
LMS7002M_RegistersMap *LMS7002M::BackupRegisterMap(void)
//BackupAllRegisters(); return NULL;
auto backup = new LMS7002M_RegistersMap();
Channel chBck = this->GetActiveChannel();
this->SetActiveChannel(ChA);
*backup = *mRegistersMap;
this->SetActiveChannel(chBck);
return backup;
void LMS7002M::RestoreRegisterMap(LMS7002M_RegistersMap *backup)
//RestoreAllRegisters(); return;
for (int ch = 0; ch < 2; ch++)
//determine addresses that have been changed
//and restore backup to the main register map
std::vector<uint16_t> restoreAddrs, restoreData;
for (const uint16_t addr : mRegistersMap->GetUsedAddresses(ch))
uint16_t original = backup->GetValue(ch, addr);
uint16_t current = mRegistersMap->GetValue(ch, addr);
mRegistersMap->SetValue(ch, addr, original);
if (ch == 1 and addr < 0x0100) continue;
if (original == current) continue;
restoreAddrs.push_back(addr);
restoreData.push_back(original);
//bulk write the original register values from backup
this->SetActiveChannel((ch==0)?ChA:ChB);
SPI_write_batch(restoreAddrs.data(), restoreData.data(), restoreData.size(), true);
//cleanup
delete backup;
backup = nullptr;
int LMS7002M::TuneRxFilter(float_type rx_lpf_freq_RF)
int status;
if(RxLPF_RF_LimitLow > rx_lpf_freq_RF || rx_lpf_freq_RF > RxLPF_RF_LimitHigh)
return ReportError(ERANGE, "RxLPF frequency out of range, available range from %g to %g MHz", RxLPF_RF_LimitLow/1e6, RxLPF_RF_LimitHigh/1e6);
uint8_t g_tia = Get_SPI_Reg_bits(LMS7param(G_TIA_RFE));
if(g_tia == 1 && rx_lpf_freq_RF < 4e6)
rx_lpf_freq_RF = 4e6;
Log(LOG_WARNING, "Rx LPF min bandwidth is 4MHz when TIA gain is set to -12 dB");
if(mcuControl->ReadMCUProgramID() != MCU_ID_CALIBRATIONS_SINGLE_IMAGE)
if((status = mcuControl->Program_MCU(mcu_program_lms7_dc_iq_calibration_bin, IConnection::MCU_PROG_MODE::SRAM)))
return ReportError(status, "Tune Rx Filter: failed to program MCU");
//set reference clock parameter inside MCU
long refClk = GetReferenceClk_SX(false);
mcuControl->SetParameter(MCU_BD::MCU_REF_CLK, refClk);
return -1;
return status;
int status;
if(tx_lpf_freq_RF < TxLPF_RF_LimitLow || tx_lpf_freq_RF > TxLPF_RF_LimitHigh)
return ReportError(ERANGE, "Tx lpf(%g MHz) out of range %g-%g MHz and %g-%g MHz", tx_lpf_freq_RF/1e6,
TxLPF_RF_LimitLow/1e6, TxLPF_RF_LimitLowMid/1e6,
TxLPF_RF_LimitMidHigh/1e6, TxLPF_RF_LimitHigh/1e6);
//calculate intermediate frequency
float_type tx_lpf_IF = tx_lpf_freq_RF/2;
if(tx_lpf_freq_RF > TxLPF_RF_LimitLowMid && tx_lpf_freq_RF < TxLPF_RF_LimitMidHigh)
Log(LOG_WARNING, "Tx lpf(%g MHz) out of range %g-%g MHz and %g-%g MHz. Setting to %g MHz", tx_lpf_freq_RF/1e6,
TxLPF_RF_LimitMidHigh/1e6, TxLPF_RF_LimitHigh/1e6,
TxLPF_RF_LimitMidHigh/1e6);
tx_lpf_IF = TxLPF_RF_LimitMidHigh/2;
if (!controlPort){
lime::error("Tune Tx Filter: No device connected");
return -1;
return ReportError(status, "Tune Tx Filter: failed to program MCU");
int ind = this->GetActiveChannelIndex()%2;
opt_gain_tbb[ind] = -1;
mcuControl->SetParameter(MCU_BD::MCU_BW, tx_lpf_freq_RF);
mcuControl->RunProcedure(6);
lime::error("Tune Tx Filter: MCU error %i (%s)", status, MCU_BD::MCUStatusMessage(status));
return -1;
std::vector<uint16_t> regsToSync = {0x0105, 0x0106, 0x0109, 0x010A, 0x010B};
if(tx_lpf_IF <= TxLPF_RF_LimitLowMid/2)
Log(LOG_INFO, "Filter calibrated. Filter order-4th, filter bandwidth set to %g MHz."
"Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active", tx_lpf_IF/1e6 * 2);
else
Log(LOG_INFO, "Filter calibrated. Filter order-2nd, set to %g MHz", tx_lpf_IF/1e6 * 2);
return 0;
This file has been truncated. show original
#include "Logger.h"
#include <cmath>
#include <iostream>
#include <assert.h>
#include "MCU_BD.h"
#include "Logger.h"
#ifdef _MSC_VER
#include <ciso646>
#endif
return backup;
//cleanup
delete backup;
backup = nullptr;
int status;
return -1;
return status;
int status;
if (!controlPort){
return -1;
return -1;
else
return 0;
Another thing you may want to look into if the noise is still present using sensible sample rates is to try a USB cable with better shielding, noise could be coming from USB 3.0. Or from the PC, try moving the LimeSDR further away.
USB 3.0 devices and cables may interfere with wireless devices operating in the 2.4 GHz ISM band. This may result in a drop in throughput or complete loss of response with Bluetooth and Wi-Fi devices. Various strategies can be applied to resolve the problem, ranging from simple solutions such as increasing the distance of USB 3.0 devices from Wi-Fi routers and Bluetooth devices, to applying additional shielding around internal computer components.
There were some devices (for example Vivo Xpla...
