Whilst trying to make a Scalar Network Analyzer work, I had a number of errors reported at different frequencies.
To simplify the problem I show the output from LimeUtil in calibration mode.
In the sequence of frequencies, some seem to work (first successful frequency is 83MHz), others do not. Is there a simple explanation for this?
derek@XPS-13:~$ LimeUtil --make
Make device
Device name: LimeSDR-Mini
Expansion name: UNSUPPORTED
Firmware version: 6
Hardware version: 2
Protocol version: 1
Gateware version: 1
Gateware revision: 30
Gateware target: LimeSDR-Mini
Serial number: 0x1d4c29f610880e
Free connection… OK
derek@XPS-13:~$ LimeUtil --cal --start 79000000 --stop 88000000 --chans=0
Reference clock 40.00 MHz
Cal sweep over [79, 88, 1] MHz, channels=0, dir=BOTH
@@ Calibrating for freq = 79 MHz
LNAL has no connection to RF ports
Selected RX path: LNAW
Rx calibration finished
Selected TX path: Band 2
Tx Calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)
Error calibrating (skipping)
Fast Tune success; vco=1 value=32
@@ Calibrating for freq = 80 MHz
Rx calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)
Fast Tune success; vco=1 value=39
@@ Calibrating for freq = 81 MHz
@@ Calibrating for freq = 82 MHz
Fast Tune success; vco=1 value=40
@@ Calibrating for freq = 83 MHz
Fast Tune success; vco=1 value=51
Tx calibration finished
@@ Calibrating for freq = 84 MHz
Fast Tune success; vco=1 value=63
@@ Calibrating for freq = 85 MHz
Fast Tune success; vco=1 value=75
@@ Calibrating for freq = 86 MHz
Fast Tune success; vco=1 value=83
@@ Calibrating for freq = 87 MHz
Fast Tune success; vco=1 value=93
@@ Calibrating for freq = 88 MHz
Fast Tune success; vco=1 value=103
Cleanup…
