Hope someone can help. I have a LimeSDR USB (original one, full size) and I can’t seem to get it to work.
I’ve run the LimeQuickTest from within Linux and the RF Loopback test seems to be the point where it failed (although sometimes the LMS7002M Test fails). Here’s an example of the failure:
->Start time: Mon Jun 27 21:30:02 2022
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009060A02430D1E, HW=4, GW=2.23
Serial Number: 0009060A02430D1E
Chip temperature: 45 C
->FX3 GPIF clock test
Test results: 38060; 41816; 45572 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112921 (min); 5113057 (max) - PASSED
->Clock Network Test PASSED
->Read data: 11 02 16 11 02 16 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
SetFrequencyCGEN(80 MHz) failed
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.15 seconds
I’m not a super strong LimeSDR user, in fact I only really ever have used it once, so I could really use some help on the next steps for troubleshooting. I searched and didn’t see any similar problems.
Any ideas?
