i might have one but i was never really to good with it and not sure if it was fully functional.
i havent used it in a year or so and i know for sure the Receive work but not sure on the Tx.
i remember i did some firmware update and i think the Tx lost sensitivity or something.
if someone wants me to run some tests and figure out what works and what dont i would be willing to sell probably.
im in a windows 11 enviroment but i probably could load some linux live distro or if i had to i could do a seperate hdd install but i prefer to stay in widnows 11 if possible.
i also wanted to add i have alot of other items to go with it.
i have 3 or 4 SDR’s (Elonics E4000) and 3 R820T2 or something like that and alot more then that.
if you are serious let me know.
my email is tdbone1@hotmail.com
i probably should have started a new thread but i really wasnt looking to seel. i always check back about every 6 months or so looking for that quick scan think like the hackrf has.
this time i bumped into a thread where people were looking for a lime mini and thought i might reply.
maybe there is nothing wrong after all.
i booted into ubuntu and installed some software.
here are the results
ubuntu@ubuntu:~$ Lime
LimeQuickTest LimeSuiteGUI LimeUtil
ubuntu@ubuntu:~$ LimeQuickTest
[ TESTING STARTED ]
->Start time: Fri Mar 25 21:55:40 2022
->LimeSuite version: 20.10.0+dfsg-5
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3BD0C4F0CDFF, HW=1, GW=1.30
Serial Number: 1D3BD0C4F0CDFF
Chip temperature: 34 C
[ Clock Network Test ]
->REF clock test
Test results: 56829; 4490; 17687 - PASSED
->VCTCXO test
Results : 6710988 (min); 6711153 (max) - PASSED
->Clock Network Test PASSED
[ FPGA EEPROM Test ]
->Read EEPROM
->Read data: 12 03 10 12 03 10 02
->FPGA EEPROM Test PASSED
[ LMS7002M Test ]
->Perform Registers Test
->External Reset line test
->LMS7002M Test PASSED
[ RF Loopback Test ]
->Configure LMS
->Run Tests (TX_2 → LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-31.9 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 → LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-17.6 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.46 seconds
Segmentation fault (core dumped)
ubuntu@ubuntu:~$ LimeUtil --info
LimeSuite information summary
Version information:
Library version: v20.10.0+dfsg-5
Build timestamp: 2022-01-24
Interface version: v2020.10.0
Binary interface: 20.10-1
System resources:
Installation root: /usr
User home directory: /home/ubuntu
App data directory: /home/ubuntu/.local/share/LimeSuite
Config directory: /home/ubuntu/.limesuite
Image search paths:
- /home/ubuntu/.local/share/LimeSuite/images
- /usr/share/LimeSuite/images
Supported connections:
- FT601
- FX3
- PCIEXillybus
ubuntu@ubuntu:~$ uname -a
Linux ubuntu 5.15.0-22-generic #22-Ubuntu SMP Tue Feb 8 10:16:30 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
ubuntu@ubuntu:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu Jammy Jellyfish (development branch)
Release: 22.04
Codename: jammy
ubuntu@ubuntu:~$
oh i see something on the rf loopback test.
i did this test with a 3" coaxial dipole antenna on Rx and a terminator on Tx.
ive done this test before with both off and same results.
only think (that i remember) is that maybe i need to go into limesuite and do something on the SXT tab first then calibrate.
i forget.
