I’m using gnuradio and LimeSDR (using gr-limesdr)
I’m trying to run the WBFM example to make sure that my LimeSDR Mini is really working. (I’m aware of the self-test)
I also own an RTL-SDR which I use to make sure that the Lime is transmitting properly. I find that the LimeSDR transmits a WBFM signal with nothing on it (no audio) for a few seconds, and then abruptly stops before the audio plays (the signal goes away). I’m using 40db gain, if that mattters.
On the RTL-SDR, I’m able to see the Lime transmit for a few seconds, before the music file starts. Just before the music file starts, it cuts out
In gnuradio, I added a WBFM decoder connected to an audio sink just to make sure the audio file is playing and the issue is not in the encoding or modulation.
Anyone else with this problem? I’m on a Debian machine with USB 3.0 ports. I’ve tried both through a USB 3.0 Hub and directly. I also tried it on my old Debian machine with USB 2.0. I’ve followed calibration instructions as well.
Logs:
LimeSuite Sink (TX) info
Connecting to device
LimeSuite version: 19.04.0-gabf82140
gr-limesdr version: 2.1.4
Device list:
Nr.:0 device:LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D4C4445A57EF3
INFO: device_handler::open_device(): no serial number. Using first device in the list.
Use "LimeUtil --find" in terminal to find prefered device serial.
Reference clock 40.00 MHz
Using device: LimeSDR-Mini(1D4C4445A57EF3) GW: 1.30 FW: 6
INFO: device_handler::set_samp_rate(): set sampling rate: 2.4 MS/s.
INFO: device_handler::set_rf_freq(): Selected TX path: Band 2
RF frequency set [TX]: 100 MHz.
INFO: device_handler::set_analog_filter(): Filter calibrated. Filter order-4th, filter bandwidth set to 5 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
TX LPF configured
INFO: device_handler::set_digital_filter(): digital filter CH0 [TX]: 2 MHz.
INFO: device_handler::set_gain(): set gain [TX] CH0: 40 dB.
INFO: device_handler::set_antenna(): CH0 antenna set [TX]: BAND1.
INFO: device_handler::calibrate(): Tx calibration finished
INFO: device_handler::set_nco(): NCO [TX] CH0: 0.2 MHz (0 deg.)(UPCONVERT).
gr::log :INFO: audio source - Audio sink arch: alsa
gr::log :INFO: audio_alsa_sink0 - [default]: unable to support sampling rate 2400000
Card requested 192000 instead.
len(interp_taps) = 668
INFO: sink_impl::init_stream(): sink channel 0 (device nr. 0) stream setup done.
Source of GRC: https://github.com/jakeson21/gr-limesdr-examples
