I’m currently building an ssb transmitter using gnuradio/limesdr mini/linux but I can’t get the sdr to transmit. Even with a simple flowgraph which modulates a sine wave, the transmissions starts and stops immediatly. The error is as follows:
LimeSuite Sink (TX) info
Devices found: 1
Device list:
Nr.:|0|device:|LimeSDR Mini, media=USB 2.0, module=FT601, addr=24607:1027, serial=1D588DD8F3BDAD
New connection
Reference clock 40,00 MHz
Device number 0 from the list is used.
INFO: device_handler::set_chip_mode(): SISO mode set for device number 0.
INFO: device_handler::set_analog_filter(): Filter calibrated. Filter order-4th, filter bandwidth set to 10 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
TX LPF configured
INFO: device_handler::calibrate(): Tx calibration finished
INFO: sink_impl::init_stream(): sink channel 0 (device nr. 0) stream setup done.
popping from TX, samples popped 204/1020
INFO: device_handler::close_device(): Disconnected from device number 0.
The self-test is passing.
Do yo know what this behaviour is?
              Hello @sigrokBlack,
Can you provide which version of GNURadio and gr-limesdr and LimeSuite you are using? Flowgraph with which this happens would also be helpful.
Regards,
Richard
              Hi, the versions are:
GNU Radio: 3.7.13.4
gr-limesdr: 0.9~beta-1+b1 (installed from debian repo)
LimeSuit: 18.06.0
The flowgraph:
And the .grc
file
The output when using the osmocom sink:
    gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.13.4
    built-in sink types: uhd hackrf bladerf soapy redpitaya freesrp file
    [INFO] Make connection: 'LimeSDR Mini [USB 3.0] 1D588DD8F3BDAD'
    [INFO] Reference: 40 MHz
    [INFO] Filter calibrated. Filter order-4th, filter bandwidth set to 6 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
    [INFO] TX LPF configured
    [INFO] Tx calibration finished
    Press Enter to quit: e[1me[33m[WARNING] popping from TX, samples popped 0/1020e[0m
    >>> Done
And the output when using the LimeSuit Sink:
Devices found: 1
Device list:
Nr.:|0|device:|LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D588DD8F3BDAD
New connection
Filter calibrated. Filter order-2nd, set to 130 MHz
TX LPF configured
Press Enter to quit: popping from TX, samples popped 0/1020
>>> Done (return code -11)
In both case you hear the calibration sound and afterwards the transmission stops and the errors appear
Regards,
Joshua
              I tried your example using Gnu Radio 3.7.13.5 (I recently upgraded because something was not working in the older version) and it transmitted a growling sound with the Limesuite Sink -
Blockquote
Connecting to device
Devices found: 1
Device list:
Nr.:|0|device:|LimeSDR Mini, media=USB 2.0, module=FT601, addr=24607:1027, serial=1D40E98019939A
INFO: device_handler::open_device(): no serial number. Using first device in the list. Use “LimeUtil --find” in terminal to find prefered device serial.
INFO: device_handler::set_samp_rate(): set sampling rate: 8 MS/s.
INFO: device_handler::set_rf_freq(): Selected TX path: Band 2
RF frequency set [TX]: 433 MHz.
TX LPF configured
INFO: device_handler::set_gain(): set gain [TX] CH0: 60 dB.
INFO: device_handler::set_antenna(): CH0 antenna set [TX]: BAND1.
Done (return code -15)
Blockquote
Can you please update LimeSuite and gr-limesdr to latest versions?
Regards,
Richard
              Hi, thanks for the hint, I didn’t know that the versions in the repo were so far behind. I installed everything from source and now it is working. I could have thought of this myself… but I didn’t… arrgh.
Thanks for your help!
Regards,
Joshua
