Hi limesdr enthusiast,
I finally got some time to play with the LimeSDR-USB I bought, and after succesfully installing the driver and the photos sw I faced the GW 0 Ver 0 issue.
I went through all the posts that talk about this issue and did many testing:
=> tested in two different laptops in USB 3.0 and USB 2.0 port.
=> Tested with a 12V 1A power supply.
=> Tested with an industial hub that can source 4.5A per USB 2.0 port.
=> Tested with the quasi all the Limesuit from 2018 up to 2019.
I got the same behavior:
When the board is powered, only the led 8 is green. All the others are tuned off.
If I exercise a small pressure on the FPGA, I got the LED 8 green, the LED 2 green and the LED 1 blinking red and green. If I reset the FX3, I go to the LED 8 green state again.
Sometimes after the small pressure, I got the LED 8 Green, LED 2 red and LED 1 blinking red and green.
All this suggest that there is a HW failure. I was planning to JTAG the FPGA but the pod I have is not compatible with the small connector on the card.
Can someone help with this issue?
Thanks.
PS: Copy of the log:
C:\Program Files\PothosSDR\bin>LimeUtil.exe --make
Make device
Undefined/Failure
Gateware version mismatch!
Expected gateware version 2, revision 21
Undefined/Failure
Device name: LimeSDR-USB
Expansion name: UNSUPPORTED
Firmware version: 4
Hardware version: 4
Protocol version: 1
Gateware version: 0
Gateware revision: 0
Gateware target: UNKNOWN
Serial number: 0x9070602460925
Free connection… OK
C:\Program Files\PothosSDR\bin>LimeUtil.exe --update
Connected to [LimeSDR-USB [USB 2.0] 9070602460925]
Undefined/Failure
Undefined/Failure
Existing firmware is same as update (4)
[100%] 580050/580050 Bytes programming: completed (C:\Users\abou\AppData\Roaming/LimeSuite/images/19.04/LimeSDR-USB_HW_1.4_r2.21.rbf)
Programming update complete!
Make device
Read(64 bytes) failed
Firmware version: 4
Hardware version: 4
Protocol version: 1
Gateware version: 0
Free connection… OK
