I bought the LimeSDR a while ago and it has been sitting in my projects backlog until this week. I bought the QRP enclosure and I am following their directions:
http://shop.qrp-labs.com/limesdr
I populated the 2-pin fan header and the LED headers. The LEDs and the fan work fine; I’ve got TX and RX lights and the FPGA1 light on.
I ran self test last week and it came back all good, but after doing this work I ran it again and CH0 is experiencing serious signal loss on LNA-H when looping back from TX2 at 2500MHz. I have pasted my test results below.
It kinda seems clear that I have done this damage
considering the chain of events. My board is still usable via the other antenna inputs but this is a huge bummer. Is there any way for me to fix this? Any ideas about what component I fried?
I’d like to spare the internet pictures of my terrible soldering; it looks like I may have toasted the corner of IC1-7 a little bit but I definitely didn’t short anything.
Thanks for the help!
radiodev@cd6dee7a0082:~$ LimeQuickTest
->Start time: Fri Jul 13 20:52:17 2018
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009070602442B3B
Serial Number: 0009070602442B3B
->FX3 GPIF clock test
Test results: 32024; 35780; 39536 - PASSED
->Si5351C test
CLK0: 17553 / 17554 - PASSED
CLK1: 17553 / 17554 - PASSED
CLK2: 17553 / 17554 - PASSED
CLK3: 17553 / 17554 - PASSED
CLK4: 17553 / 17554 - PASSED
CLK5: 17553 / 17554 - PASSED
CLK6: 17553 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112895 (min); 5113029 (max) - PASSED
->Clock Network Test PASSED
->Read data: 11 09 04 11 09 04 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.7 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-17.6 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-17.3 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-20.1 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-42.1 dBFS, 5.00 MHz) - FAILED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-14.7 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.53 seconds
