@gasparka I’m using a desktop computer, not a laptop.
@sven Today I’ve been using Pothos Flow (I don’t use GRC as it seems to hang more often) and I’ve seen some errors.
Opening the flow works:
SoapySDR: Make connection: 'LimeSDR-USB [USB 3.0] 987654321ABCD'
SoapySDR: Reference clock 30.72 MHz
SoapySDR: Device name: LimeSDR-USB
SoapySDR: Reference: 30.72 MHz
SoapySDR: LMS7002M calibration values caching Disable
SoapySDR: RX LPF configured
SoapySDR: Rx calibration finished
Starting it though often does not:
Pothos.Block.work: SoapySDRSource0: Exception: SDRSource::work(): readStream TIME_ERROR
After starting/stopping the flow several times, it finally works. Then after some time I get
SoapySDR: Read(64 bytes) failed
Running the LimeQuickTest gives me the following:
->Start time: Fri Oct 5 10:57:51 2018
Gateware version mismatch!
Expected gateware version 2, revision 17
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=000987654321ABCD, index=0
Serial Number: 000987654321ABCD
->FX3 GPIF clock test
Test results: 1; 0; 0 - PASSED
->Si5351C test
CLK0: 2 / 17554 - FAILED
CLK1: 2 / 17554 - FAILED
CLK2: 2 / 17554 - FAILED
CLK3: 2 / 17554 - FAILED
CLK4: 2 / 17554 - FAILED
CLK5: 2 / 17554 - FAILED
CLK6: 2 / 17554 - FAILED
FAILED
->ADF4002 Test
Result: 0 - FAILED
FAILED
Results : 4 (min); 4 (max) - FAILED
FAILED
->Clock Network Test FAILED
->Read data: 12 03 02 12 03 02 02
->FPGA EEPROM Test PASSED
RegistersTest() failed
->LMS7002M Test FAILED
SetFrequencySXT(1250 MHz) - cannot deliver frequency
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.40 seconds
You’ll have noticed at the beginning the
Expected gateware version 2, revision 17 But found version 0, revision 0.
After reprogramming the FPGA I can again access the Lime, and the LimeQuickTest runs fine.
I tried the same with a 2nd Lime. I also get the same Pothos.Block.work: SoapySDRSource0: Exception: SDRSource::work(): readStream TIME_ERROR when trying to start the flow (@joshblum any idea what the cause might be?), but it seems to happen less frequently than with the 1st Lime. I haven’t been able to get the same error as the 1st Lime through Pothos yet.
@Zack Can this be an issue with the Lime itself? FYI previously I was using an older version of FPGA (2.16) and was able to get that “cannot deliver frequency” on the 2 boards (but more often on the 1st one).
